Question about Pool & Spa
I have a Blue Haven Riva Spa. I have just refilled the spa after emptying it and cleaning it out completely. It now has an Error Code on the display ER 6. Does anyone know what this means or how I can fix it?
  • 11 Answers
SOURCE: spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Posted on Jan 28, 2009
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
  • 246 Answers
SOURCE: Blue Haven 6100 reset problem
you cant reset mean new star you must enternew settings
Posted on Aug 31, 2009
  • 246 Answers
SOURCE: SN ?Non Functional High Temp Sensor? error message
unplug and plug after 20 sec. turn pump fast and wait for 1 min if nothing air is trap anf need to be out
Posted on Sep 13, 2009
How do I open the drain Plug on a Blue Haven Stand Alone Spa to empty the water?
if no drain at bottom hose size then pump out with simer pump
May 21, 2016 | Pool & Spa
Error code PR
pressure either switch or recirculation pump
Feb 16, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
--- code keeps coming on
this is the nature of the error code displayed.
(---) =Unknown water temperature. (Displays when first powered up after refill).
RodUS Parts Center888-521-6183
Oct 19, 2012 | Jacuzzi Pool & Spa
I have a Blue Haven 6100 control panel with error code 6521 Rev GG and 6543 Rev B01
make sure 4 pin connector is plugged in also make sure wire isn't knicked or wires touching
Mar 17, 2012 | Jandy AquaLink RS2/6 All Button Dual...
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
I have refilled spa and on turning on the display is saying Error 6
06: Heater Thermal Cut Out has failed. It means that the spa can overheat as the built-in protection is disabled.
Call your spa repairman for help...
Jan 24, 2010 | Computers & Internet
Jul 06, 2009 | Jandy AQUALINK RS TELELINK KIT
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
