Question about Cameras
How to use olympus sp 180 uz - Cameras
  • 48 Answers
SOURCE: Problem with camera OLYMPUS SP 500 UZ
This sounds like a CCD issue in the camera. The CCD is the part in the camera that captures the image (the "digital film") if you will and converts it to a format the camera can read.
When they go bad a lot of times you will see weird colorations and/or stripes, very similar to what you are describing.
You can try eBay for a place to buy, or maybe check the manufacturer.
Posted on Dec 18, 2007
SOURCE: Camera not staying on.
Well, not sure if I have a solution. What I did has worked so far. It seemed to me the problem had to be a battery connector because my camera did this when the batteries got low. Then it got to doing it all the time. So I removed the back of the camera, cleaned it and took off and re-installed the battery door. First remove the batteries and the card. There are 8 screws, two on each side. The side with the card, you will have to open the card door to get to those two screws. Be sure to keep the screws separate because they are different sizes. Once the screws are removed, you can take off the back. Be care because there is a ribbon and a wire going from the camera board to the LCD on the back. Mine came off rather easily. I also removed the battery door. We stopped tearing apart at this time because I don't have the correct tools and really don't know what I was doing. We took a can of pressurized air and cleaned out the inside behind the board and around the battery connections. We put the camera back together. I haven't had any problems since and it has been about a week and I have been checking the working operation since. I think it has more to do with the battery door than the actual cleaning of the inside. While you have it open, you might as well clean it.
Posted on Jun 30, 2009
SOURCE: can i use the olympus sp-550 UZ as a web cam?
It is not possible to use this as a webcam as the camera is not capable of sending streaming data over the data cable rpovided with it and also the software rpovided with it (drivers) is not programmed for the camera to be used as webcam.
Posted on Aug 12, 2009
  • 52 Answers
SOURCE: 'zoom error' on olympus sp-560
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Posted on Jan 12, 2010
  • 6 Answers
SOURCE: Zoom Error on Olympus SP-500UZ
I have this exact same camera and I had the exact same error. Since it was no longer under warranty, I decided to see what I could do myself. The zoom tube has a ring surrounding it and on the bottom of the ring there is a tiny Phillips head screw. I removed the screw and loosened and jiggled the ring a little bit. I then turned on the camera and it worked. I replaced the screw and it still worked. I don't know if I was just lucky or what. I would not recommend trying this if the camera is still under warranty. I figured I had nothing to loose.
Posted on Feb 23, 2010
Adjust microphone level
You can't adjust the volume of the recording, but you can adjust the volume of the playback. See page 31 of this manual.
Mar 22, 2013 | Olympus SP-510 UZ Digital Camera
Will my olympus sp500uz support the new M+ 2gb card?
According to the Specifications page of the manual, the SP-500 UZ supports xD cards from 128MB to 1GB.
Jun 23, 2011 | Olympus SP-500 UZ Digital Camera
Looking for a manual for the Olympus SP-560 UZ Digital Camera
You can download a PDF manual and/or order a printed manual from the manufacturer's web site at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1316
Jan 08, 2011 | Olympus SP-560 UZ Digital Camera
Can I zoom when recording on the olympus sp 800
Zooming when recording video on the Olympus SP-800uz is only possible when the sound is set to off. Set the zoom to the setting you want before recording, after that start recording.
Dec 13, 2010 | Olympus Bag / Case For Sp-600 Sp-800...
Blue line on pictures. SP-510 UZ
From what I am told your CCD is damaged. I have the same problem with my Z812.
Oct 29, 2009 | Olympus SP-510 UZ Digital Camera
Can i use the olympus sp-550 UZ as a web cam?
Aug 12, 2009 | Olympus SP-550 UZ Digital Camera
Conversion of LCD
Unfortunately such conversion is not possible. If the "vari angle" screen is an essential your best approach would be to dispose of the SP 550 UZ and buy another camera meeting your need. Sorry!
Mar 25, 2008 | Olympus SP-550 UZ Digital Camera
Raw picture on olympus sp 550 uz
Assuming your SP 550 UZ is similar to the 510 UZ "RAW Mode" is not available in "Auto" or any of the "Scene" modes. If you set your camera to "P" and then access the Image Quality item in the Menu RAW is available as an option.
Hope this helps.
Mar 02, 2008 | Olympus SP-550 UZ Digital Camera
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
