Question about Toys
285 massey ferguson pto wont disengage
Pto will not disengage
  • 3 Answers
SOURCE: looking for repair manual for massey ferguson
Call JEN-SALES at 800-443-0625 or 507-826-3666 or www.jensales.com
Posted on May 28, 2009
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Posted on Nov 21, 2009
  • 165 Answers
SOURCE: Massey Ferguson 35 has no spark, I have replaced
Test the plug wires, coil wire---could be the ends of the wires. Points could be burned and replace the condenser?
Posted on Feb 27, 2010
captjack163
  • 13 Answers
SOURCE: What sort of oil is used in the gearbox of a
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Posted on May 01, 2010
SOURCE: t20 massey ferguson tractor. hydralics not working
ferguson ted20 hyd arms stuck up wont drop
Posted on Feb 25, 2011
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Shift fork for a 2675 massey ferguson
check that you have the correct lever in position
there is a lever that separates the drive from the pto operation so that you can run the pto with out the gear box
Aug 03, 2016 | Toys
What is involved in changing PTO shaft seal on a 471 massey ferguson
The seal in the PTO or the hook up point on the transmission?
Jul 18, 2016 | Melissa Masse Toys
Engine stalled while pto engaged. Now pto will not disengage engine will not start. Act like it is locked up.
You will need to disengage the PTO before it will start as it is holding the engine back from starting. You should be able to disengage the PTO and roll the engine over and it should free itself up unless a bearing is hung up.
Apr 10, 2016 | Garden
Pto won't disengage, unable to start tractor. pto attached to post hole digger in ground
It could be gear bound and not allowing it to disengage, i experienced that a few times in my farming days, we dug a lot of postholes with a PTO driven digger. What usually happened is i ended up getting caught on rocks and stalled out because i had the engine speed to low. What i generally had to do to fix it was remove the PTO shaft from the digger, disconnect from the tractors output shaft, then get it started and everything moving, then disengage the PTO and reconnect the post hole digger, then give her hell and get the engine speed up before re-engaging the PTO, that would generally shock it loose. If not then i would have to disconnect the PTO shaft again and spin it backwards by hand to rotate the digger in the opposite direction to remove the hangup.
Nov 25, 2015 | John Deere 670 770 870 970 1070 Compact...
What could the possible reasons why the pto will not disengage on my MTD 42" Zero Turn Mower.
Basically your PTO is an electro magnetic clutch....when power is applied (12 volts) from the battery, the magnet is energized and the two plates come together and you have then energized your PTO clutch and it should drive the V-belt....so If you disconnect the power to the magnet the magnet becomes denergized and the two plates move away from one another ,thus the v-belt stops turning .
It could be the switch,or more than likely it is a "relay" that has gone bad ,ie, the contacts on the relay have become pitted with use and stick when they get hot from use....thus when you disengage the PTO switch the relay stays in contact thus delivering power to your PTO clutch .....if you have a wiring diagram of your unit you should be able to find the "safety or PTO relay" again this is just my theory!
If you can use a meter,you could check for voltage on the PTO wire when you disengage the PTO switch,if power is still present then we know it's an electrical issue with the switch or relay ,OR some how power is back feeding down this wire that keeps the clutch energized????? Maybe two wires making contact ????
Unfortunately a good small engine mechanic may be the way to go on this repair ......most people have a clutch that won't engage !
I hope this sheds some light on your issue ,Jim
Feb 11, 2015 | Mtd Gold 42" Zero-Turn Mower -
I have a cub cadet ags2130 that stalled with the pto engaged. Now the engine will not start due to the pto not disengaging. How do I disengage the pto.
Sounds the clutch may have failed but try just unplug it just it an electrical problem. Also check to see any of the v-belt cords came loose and wrap themselves up in the clutch. I had one a couple years that this was the problem.
Another thing you could do is completely remove the PTO clutch to see you have a bearing failure in it.
Oct 23, 2014 | Garden
Toys Logo
93 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
