Question about Ryobi Saws
RJ165V Ryobi Reciprocating Saw - how do I adjust the shoe?
rowdy45176
  • 2176 Answers
SOURCE: reciprocating saw problem
OK just looked at the Searspartsdirect.com website and there are 2 parts that I think it could possibly be. One is the SHOE part # 399725-00 list 4.86 in stock and or guard 157325-00 list 4.59 also in stock. I would suggest that you go to this site and confirm which one you need, but the shoe is the piece that does ride against the work surface. Good Luck and let me know if I can help further
Posted on Jan 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
Posted on May 18, 2009
  • 885 Answers
SOURCE: clutch adjustment on ryobi reciprocating saw # rj160v
The Ryobi RJ160V does not have a clutch, it has a direct drive system: the armature has a gear pressed on the end of it that turns a bevel gear with an off-set pin on it. This pin fits into a slot on the end of the saw bar assembly which is what you attach the blade to. If you have slipping it could be stripped armature gear teeth or bevel gear teeth or both or the pin on the bevel gear is broke off.
Posted on Feb 23, 2012
  • 304 Answers
SOURCE: how to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
Posted on Jun 05, 2012
  • 304 Answers
SOURCE: I want to find a repair center for my ryobi reciprocating saw
Go to http://www.ryobitools.com/support/service_center_locators for your nearest dealer
Posted on Jun 22, 2012
Remove rubber boot ryobi rj150v
Ryobi removal Reciprocating Saws Questions & Answers ...
www.fixya.com > Forum > Tags > removal > Reciprocating Saws
We have a ryobi rj150v model reciprocating saw (older model) which needs the ... How do I remove the rubber boot which covers the front of the Rigid R3002 ...
How do I remove the rubber boot which covers the front of ...
www.fixya.com/.../t16652505-remove_rubber_boot_covers_front_rigid
Feb 18, 2013 - How do I remove the rubber boot which covers the front of the Rigid R3002 recip. saw? - Ryobi Ridgid R3002 Fuego Orbital question. ... We have a ryobi rj150v model reciprocating saw · Ryobi Reciprocating Saws · 1 Answer ...
[PDF]operator's manual reciprocating saw rj150v-02 - Gar
Nov 26, 2015 | Ryobi Saws
HOW DO YOU put new boot back on ryobi reciprocating saw?
No. You spin it onto the tool clockwise. When you get far enough on, the lever will slip right into the slot.
I like to take my shoe off, and use my foot to hold the hand grip while sitting down. This allows me to use both hands to twist the rubber grip off/on.
Jun 24, 2015 | Ryobi Rj165v Reciprocating Saws
How do I install a blade
Your Ryobi saw may have a twist-type chuck. You twist it and hold it twisted open to insert the blade, then release it secure the blade.
Nov 17, 2014 | Ryobi Reciprocating Saw Rj160v
Ryobi reciprocating saw motor rund but blade doesnt
A Ryobi might not have that nut. They are likley a ring gear drive which is different. I'd open it up and look at the gears. Make sure no teeth are missing and that none are worn down. If they're worn they would probably look rounded. If the gears are bad the saw is more than likely not worth repair. Ryobi saws are not very expensive compared to the cost of repair parts.
Mar 10, 2014 | Ryobi Rj165v Reciprocating Saws
The cover is a very tight, stretch-fit boot. After removing the shoe release lever, shoe pin and shoe assembly you have to pull, stretch and pry the boot off. It helps a lot to have someone assist The boot is fairly tough rubber but be careful not to tear it. It helps to have the boot warm to almost hot so it stretches easier.
Feb 18, 2013 | Ryobi Ridgid R3002 Fuego Orbital...
Jun 19, 2012 | Ryobi Saws
How to remove broken blade stub from cordless ryobi reciprocating saw
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Clutch adjustment on ryobi reciprocating saw # rj160v
Feb 21, 2012 | Ryobi Saws
Ryoby Model rj165v
Well, here is the breakdown for the model you posted, if you can post what the tool is doing, I will be willing to help you figure out what the problem is.
http://www.ereplacementparts.com/ryobi-rj165v-variable-speed-reciprocating-saw-parts-c-7931_8031_8133.html
Nov 26, 2010 | Garden
Saws Logo
77 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
