AFTER AWHILE TURNS OFF
AT START AFTER30 MINUTES TURNS OFF AT NORMAL TEMPRETURE I,M ELECTRNIC TECHNICIAN WITH MORE THAN10 YEARS OF REPAIRING EXPRIENCE.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Locate and monitor the main supply output voltages from the power supply---is one going high after a while--excessive or low output will trigger the latch or shutdown circuit all sets have.
Also suspect a possible issue with poor or bad solder connections anywhere in the set--tapping sometimes will confirm this.
Posted on Nov 01, 2012
Why is the picture on my RCA tv goes slowly darker as i watch it?
Contact any service technician. Its CRT base connector socket, or, LOT is faulty. This is not a user repairable fault. Replacement to any one among component stated above, or both, might need replacement. Gopakumar Gopalan Google
Mar 05, 2014 | RCA Televison & Video
My Miele dryer Miele Novotronic 494C does not dry clothes
Check breaker, then wiring. This can be a thorough job. Your element is probably burned out. If it is older than10-12 years,this is normally it. One other thing to look at is the relay switch which is located under the top. It will shut down if there is an electrical problem.
Mar 15, 2013 | Miele Dryers
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
My 40 inch LCD sanding tv won't turn on for awhile. It keeps doing the clicking sound for about two minutes before it catches and turns on. Shat should I do?
> Shat should I do?
Take it to a qualified TV/video technician, for proper trouble-shooting and repair, because this problem has no "end-user" repairable parts.
Oct 23, 2010 | Samsung SM400P 40" LCD Monitor
Hard to start after shutting off
The starter operates great when cold. When the engine gets to its normal operrating tempreture the starter gets hot. An old starter will have an expanded armature from this causing the starter to drag or just freeze up hot . When its cool it will start again. This will eventuly get hot and the armature will go bad forever on you so get it changed soon
Jan 09, 2010 | 1998 Chevrolet Cavalier
The covergence of the red,blue and yellow will not reset automatically or manually. Therefeore i have color rings around the pictures on screen.
Hi
maybe you have defective convergence correction amplifier IC,. this unit is need to diagnose with a qualified personnel technician,. or if you have knowledge in electrnic repairing i can teach you how to fix this issues
Thanks!
Jul 08, 2009 | JVC AV-65WP74 Rear Projection Television
Disney mcqueen tv DTP1363-CAR
yes it can be repaired for sure .it will cost you near to between  $10 to $ 150 plus the service charge of the technician. as sometimews this causes due to very minute short circuit and a small ic or capacitors gets blown and the cost for that 1 single capacitor is very negligible so it can be $10 also. thanks.
Jan 05, 2009 | Disney DTD1363-CAR 13" TV/DVD
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
