Question about Behringer EURORACK UB2442FX PRO Mixer
No signal through ub2442fx-pro
No signal playing through any of the channels on mixer
3 Suggested Answers
  • 5603 Answers
SOURCE: I'm using the ub2442fx but not getting enough volume
The unit should generate standard levels which then must be amplified. It LIKELY is doing that.
I suspect your amplifiers and/or speakers are insufficient. You have not told us the speakers you have or the size of the venue. The type of sound you are making is important too, as heavy bass requires BIG speakers... at least 15 inches for good reproduction.
I also would recommend you get an audio sound level meter... even an inexpensive Radio Shack one will do. This will allow you to comply with the sound level restrictions and compare speaker/amplifier sets.
If you can get to 90 Db, that is safe level.
Many venues they have massive amplifiers for say a 4000 sq ft area that have 1000 watts. This doesn't guarantee adequate sound since the efficiency of the speakers play a vast part. For good bass, the speaker cabinets need adequate physical size to match the speakers to be efficient.
A word of warning: If you have an ampliifier that generates much more than the rating of the speaker, expect to blow some speakers. Also DON'T be fooled by "peak power" ratings as they are fake, count on RMS power ratings when comparing.
Posted on Feb 06, 2010
  • 140 Answers
SOURCE: I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Posted on Jun 10, 2011
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
How do you set up for a simple pa system?
It Depends how many Channels you are wanting for a basic 2 deck set up using Cdj's you would want 4 channel 2 per deck 1 master out and 1 booth so you can hear it through your head phones but if you were doing Karaoke you would want 6 channels for 2 microphones all going 2 the master out. but it changes again if us software and controller because most software has an internal and external mix mode. Here is a video that might help
Sep 02, 2014 | Behringer EURORACK UB2442FX PRO Mixer
How to link 2 mixers
VIa, XLR, TRS, 1/4 Jack, phono,,
Jul 19, 2014 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Only the left channel on the whole board works. Is there some part that might be replaced to fix the right channel?
First analysis needs to be done to isolate what can be discovwered before opening the unit. Does the sound appear in BOTH sides of the headphones? There are MANY components that can kill the right side including cracked circuit board. Beyond a certain point one would use an oscilloscope to troubleshoot.
Jul 20, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Mixer does not sound "clean"; almost distorted
If more than one input is bad, then problem has NOTHING to do with the preamps. Check list:
1. Make sure you are using BALANCED lines everywhere... either XLR or TRS cables.
2. Make sure ALL interconnected equipment, mixers, amps, powered speakers, CD players, etc. are ALL powered from the SAME receptacle or power distribution unit.
3. Do proper setup. Select each channel PFL and set the trims so the indicator never goes into clipping, but is in the 70% range during max volume input to mics, etc..
4. During operation the sliders should be at least 50% up on used channels and the mains. Setting of levels throughout the system is important for noise free operation. Using EXCESS gain at some point results in distortion and noise. Using sliders near the bottom position results in poor signal to noise ratio.
Now re-read #2 above... and believe it. I have seen a lot of equipment blown due to ground bounce of building power. That is why the pro's run power back to their mixer from the area where the amps are powered.
Apr 28, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Behringer EURORACK UB2442FX PRO Mixer Logo
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
