Question about Acer Aspire 5315 Notebook
Labtop wont start up
Green light comes on for a couple of seconds, then goes off. only seen a white screen flash on 2 times in awhile.
  • cathy zipperer Jan 04, 2009
    it comes on with the battery and/or the plug, but only the green light and fan comes on for about 5 seconds. nothing on screen. saw white cloudy screen flashe on 2 times after trying all sorts of things.can you help me please.
    Problem Solver:
  • 5 Answers
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Posted on Jan 04, 2009
  • wilf warwick
    wilf warwick Nov 25, 2013
    thanks i will give this a try it started no problem till i changed the board but was getting code 043 and double pic on monitor thanks for your help wilf
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
Long start up time flashing green light
how long does it take to start. this set is normal to take 90 seconds. after its off awhile does it take awhile. when you first plug it up it takes 80 second to boot,. the light will flash in the bootup. when you shut this set off the set has to go through cool down before it will come back on
Oct 25, 2010 | Mitsubishi WD-57731 57" Projection HDTV
My Tv wont stay on
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com
Jun 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
SUPER DARK SCREEN, BLACK PICTURES
I have seen this several time the lens cable can cause this issue it could also be the back light or the LCD I repair these all the time If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Oct 02, 2008 | Casio Exilim EXZ75 Digital Camera
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Aug 27, 2007 | Hyundai L91A 19" LCD Monitor
Acer Aspire 5315 Notebook Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
