Question about Refrigerators
Maytag model # MBR2258xes1 side by side freezer not freezing
Freezer seems to stop freezing but fan in rear is running and fridge is cooling
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 9 Answers
SOURCE: maytag fridge model # MFF2557HEB
This has to be the evap. fan motor. I have ran into this alot. If you take the vent off the topcenter of the freezer back panel useing a simple flat head unlock the clips. Once you see the fan blades push it with your finger carefully if it spins slow and little wobblely the motor has failed. If it turns not at all then check for 120V. going into the motor by unhooking it if you get 120V motor bad if you get nothing then the Jazzboard or Highvoltage control board has failed. To install a new fanmotor is easy take your time most parts come out with a flathead screw driver and 1/4inchnutdriver. Evap. fan motor is just clipped in.
Posted on Jan 20, 2008
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Posted on Feb 28, 2009
My refrigerator keeps running inside the freezer part ice is forming.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Maytag MSD2756G Side by Side Refrigerator
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer not freezing and fridge not cooling
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
After many repairs to my maytag mzd2766ges, my fridge side cools for a while and then it stops until a new repairs
If either door is open, the airflow will be wrong. Do you see a lot of "snow" or frost building up at the bottom of the freezer rear wall?
Do you hear a fan running in the freezer compartment?
Where are your controls set?
Is the fan back by the compressor running?
Have you checked the air duct at the bottom behind the lower crisper drawers?
The main reason for this type of problem is that the (evaporator) coils below the fan would be iced up.
So, i need you to do this,
1.unscrew the back panels on the freezer side and note whether the evaporator coils were all iced up.
2. If it is iced up, then defrost the coils and then replace the defrost board in the refrigerator.
Regrigerator will be back to normal . Defrost board is located on top of refrigertor side underneath the temp control unit.
Easy repair once you remove the temp control cover. Unscrew the defrost board and plug new connection in.
Post your comments about how things turned up.
Thanx for using fixya,
Cheers.
you can also mail your comments: mailmeswami@yahoo.co.in
Sep 27, 2008 | Maytag MZD2766GES Side by Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
