Question about Honeywell Electrical Supplies
Honeywell generator error code
What is low voltage alarm code
3 Suggested Answers
  • 1383 Answers
SOURCE: High voltage low cycles
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
Posted on Dec 18, 2008
sal_kh_sab
  • 98 Answers
SOURCE: generator voltage too low
check engine speed by the sound...if normal then check AVR card...replace it...
if not normal rase it...
Posted on Oct 11, 2009
What does the code Lng/Rng mean on my Honeywell alarm panel box mean?
back up dialer (cellular, wireless) trouble. look for code after that display to see if what the error is
Dec 09, 2016 | Honeywell Home Security
I have a AEG F88060VIOP dishwasher - showing error coded ,00 and beeping. Not listed in manual - can anyone help id cause and fix please? Thanks
Fault code "i00" means "Low mains voltage"
The electronic board makes sure the dishwasher operates within certain voltage limits. If during a cycle the voltage drops below the lowest limit, the electronic board suspends all loads and interrupts the cycle under way. The "i00" alarm is then triggered. The lowest main voltage threshold is 180 Volt. If the voltage goes back to over 186 Volt, the electronic board cancels the error status and the cycle
resumes. The "i00" alarm is also deleted.
If the mains voltage continues to exceed the maximum threshold, the electronic board does not do anything.
My suggestion is to call your local electrician to check the voltage in your home.
Dado
Feb 23, 2015 | AEG Dishwashers
Honeywell 17KW generator error code 1100
You most likely have a fuel problem. Either not enough or too much pressure. What fuel are you using, propane or natural gas?
Dec 07, 2014 | Honeywell Electrical Supplies
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
The systems is working fine and no indications or warnings on the panels, but you can hear the siren at a low sound at all times. All the zones are working according to the panel and alarm monitoring...
The siren should not receive any power when in idle mode (non alarmed state). If you hear any noise, it receives some kind of low voltage. Is it powered straight from the panel or with external power supply and aux. relay? In any way - use a volt meter and measure across the sirens power terminals. If you have any voltage present check the source.
Nov 18, 2013 | Honeywell Ademco Wave 2 Wave2 Sirens For...
My Honeywell Thermostat has an error message OLOad. What does this mean
The manual says this will occur when the connected load exceeds 3800W. It goes on to say that this is a fire hazard.Not sure what could have changed.was(any) work done to the system or house? may be low voltage got crossed with line voltage
Nov 28, 2011 | Honeywell Heating & Cooling
Battery No Charge and Error codes
These are for 4.9L
P016-generator voltage out of range--Voltage is below 10 volts or above 16 volts with engine at 500rpm.
P030-Idle speed control (ISC) out of range--Check ISC for operation
A047-very low A/C refrigerant condition warning--check refrigerant level
I039-speed sensing suspension (SSS) fault--this one requires a lot of testing. Could be anything from bad connection at a strut, to bad ground, to bad strut.
I041-battery voltage too low--at 800 rpm, voltage is less than 10.6 volts
I052-keep alive memory error--means IPC lost voltage, and reset. Normal if battery was disconnected, or lost voltage.
These codes are for 4.6L
I039-loss of road sensing suspension (RSS) data--might need to replace rss module
P016-generator voltage out of range--same as above.
If you need anything else, let me know.
Dec 19, 2008 | 1994 Cadillac DeVille
Electrical Supplies Logo
151 people viewed this question
Top Honeywell Electrical Supplies Experts
Dennis Boxerman
 Kenneth
Kenneth
obsteiner
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
