Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Heat elements in oven/broiler do not heat up
I have a Frigidaire oven model PLEF398DCA ..the stove top and all controls seem to work properly but oven/broiler does not heat. I removed back panel of oven and tested for power ..When tested to ground I get 120v at 4 posts ..upper and lower filaments when either oven or broiler is turned on.....Do you know if this is correct voltage or what could be done to fix problem Thanks
  • 2 more comments
  • sleeper100 Jan 05, 2009
    Yes it is an electric oven and when going straight across I have nothing...any ideas?
    Yes it is an electric oven and when I go straight across I get nothing...0 volts
  • sleeper100 Jan 06, 2009
    When I go across wiring where it hooks into oven I get 240v....When I go from ground to any of four posts of heating elements I get 120v when oven or broiler is turned on
  • sleeper100 Jan 08, 2009
    I do have 240 across black and red when I go across heating elements I get 0 volts.... when I go from ground to any of the four posts of heating elements (2 broiler 2 oven) I get 120v
  • 530 Answers
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
  • 2 more comments
  • erica graber Jan 04, 2009
    You need to check straight across you should have 220-240V
  • erica graber Jan 05, 2009
    well there is something wrong with your electrical horizontal you should have 220-240 if not you need an electrician
    vertical shouold be zero because that is the nuetral and ground you are testing. now if you where to go from one vertical to horizontal should read 120 and if you do the other side should read 120. but to run the oven you need 220-240 if you do not have this straight across horizontal from the wall there is a problem with your house wireing
  • erica graber Jan 07, 2009
    you should have 240 across the heating element. Please be supper careful. If you do then you have a bad element but if you do not you probabley have a bad controller. Ok so straight accros the terminal block at the range i belive from red to black you should have 240v you are saying you have that? right?
Oven heats properly, but the broiler element does not heat or even get warm. Controller lights up and says broiler is activated. Galaxy stove with ES100/105 electronic oven control.
Broil element can be tested with a meter by a competent service person or by yourself if you are handy. Be sure unit is unplugged before doing any service yourself. If element tests good, then clock / control will have to be replaced
Sep 27, 2017 | Ovens
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
754 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
