Service call 231 :error 01 for oki b411d printer. What do I do.
3 Suggested Answers
SOURCE: OKi C5800ldn 231: fatal error 03
Switch off printer. Unplug power source from printer. Re-plug same and power up again. Should work Have same problem with OKI 5900
regards
Liam
Posted on Mar 22, 2009
  • 97 Answers
SOURCE: fatal error 231 on oki c5800 after changing toner,
From the service manual, doesn't look good.
A technicain will have to look at the printer.
RFID Reader I/F Error
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Posted on Mar 29, 2010
Fatal error 231 error 3
RFID Reader I/F Error An interface error was detected
01: communication error between
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
chip.
04: the RFID Tag detection error
Jul 17, 2014 | OKI C6100n Laser Printer
How can I fix oki c3530 231: fatal error 03?
PCB.
the RFID reader.
chip.
Jun 21, 2014 | OKI C5800Ldn Led Printer
Hot to reset drum counter on Oki b411d
You need a fast fuse 65 mA. Install the printer in accordance with a picture, put the components and the rest. After a reset, pull the fuse. hot-reset-drum-counter-oki-b411d-drep1qcu2aclflpmzd1fe3xv-5-0.jpg
May 12, 2014 | Oki Electric Industry B431d Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Oki b411dn error 563
The image drum cartridge has reached the end of
its life. Replace the image drum cartridge
Jan 12, 2014 | Oki Electric Industry B411d Printer
Printer stopped
Error 231 could be caused by multiple issues. The RFID R/W PCB, CU/PU PCB just to name a couple. This might be best left to an authorized service agent.
Nov 09, 2013 | Oki Electric Industry C610dtn Laser...
Error 073
This error is defined as the following... H/W Overrun detect. essentially trying to make the printer don more than it can.
Oct 02, 2013 | Oki Electric Industry B411d Printer
OKI C5650 231 FATAL ERROR 03
I tried putting 1.5mm of plastic foam under the RFID chip to raise it up in the toner cartridge. This seemed to work.
Jan 17, 2012 | Office Equipment & Supplies
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Feb 13, 2009 | OKI C5800Ldn Led Printer
4,247 people viewed this question
k24674
