Washing machine draining small rusted metal pieces
Our front-loading Kenmore washer seems to run fine until the final spin cycle when there is an awful thumping noise. When we went down to see what was going on, we discovered in the drainage sink, small rusted pieces of metal and what looks like black sand. The clothing in the washer appears to be clean.
  • 15,935 Answers
It appears your clutch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Washer will not spin out on the final cycle and then shut off
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 25, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washer is not rotating fully during wash cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
No spin cycle.
Do you hear if motor is running (an humming noise) ?if you can then It sounds like a badly worn belt that slid on the tub (the washer succeed to spin- depending on clothes weight in tub) . Open the rear panel, check for belt status and if it really worn,replace it with a genuine belt from the manufacturer.
Be aware you should disconnected power cable from the machine before starting work on it.
Come back if you need more help...
Oct 20, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
