Question about White Rodgers Home Security
White Rodgers type 1F86-244 will not let me change the temperatures
2 Suggested Answers
liteswink
  • 99 Answers
SOURCE: * APPEARS NEXT TO TEMPERATURE
The snowflake is displayed on the screen when the system is in cool position. check page four of the installation manual
Link: INSTALLATION MANUAL
Posted on May 29, 2010
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
The room temperature on my white-rodgers thermostat model 156-5299 keeps increasing
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. 156-5299 is a invalid model number To better assist you with this contact White - Rodger's technical department at 18002842925.
Sep 02, 2012 | White Rodgers White-Rodgers 1F85RF-275...
White rodgers customer service phone number
we are not white rodgers /emerson --the following links can assist you but if the trooble shooting doesnt fix problem just replace the stat
White Rodgers White Rodgers White Rodgers Thermostats Thermostat AC Wholesalers How to Troubleshoot White Rodgers Thermostat eHow
May 30, 2017 | Heating & Cooling
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
My thermostat now reads in Celsius. How do I change it back to Farenheit? IF80-54
Try the following, Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Jan 06, 2011 | White Rodgers White-Rodgers 1F85RF-275...
How to change from celcius to fahrenheit? How did get change by it's self?
Try the following. Cheers, Joseph
cess. 5:30AM.)
Nov 23, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Hello I need program instructions for a white-rodgers thermostat that has these numbers: 156 3069B. Can you help me?thanks Linda
please call the homeowner tech line at 18002842925.
or check the TYPE NUMBER of the thermostat usually it starts with 1FXX-XXX. When you have that handy visit the website of White- Rodgers, just put the type number on the search cross reference box it will lead you the way to download the instruction manual online.
Jul 24, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
May 26, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Home Security Logo
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
