Question about Refrigerators
My kenmore elite fridge model # 795.77543600 had the following problem. The inside lights apparently stayed on even though the doors were closed to the point that the ceramic fixtures turned brown and the plastic cover melted. Any idea what caused this
MNTECH
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
  • 135 Answers
SOURCE: Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Posted on Aug 27, 2009
woodchuck789
  • 4066 Answers
SOURCE: light remains on when fridge door closed. door
You can take the door switch out and replace it with a new one. You may also need to get an appliance light bulb that's not so hot.
Posted on Oct 10, 2009
localwonder
  • 6784 Answers
SOURCE: lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Posted on Dec 11, 2009
  • 161 Answers
SOURCE: The light bulbs inside my
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Posted on Jan 22, 2010
Testimonial: "This is exactly right. Both the parts and labor were covered by LG, even though the fridge is almost 3 years old."
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator freezer and fridge too cold
947f1e38-158a-4e1c-9e57-08343605a6a0.jpgKenmore uses a model number like this example=> 321.1234567 and can be found around the fresh food section door frame. I need that model number to see what parts may be causing the refrigerator to be too cold. Let me know and I will do my best to help solve this, Thanks Sea Breeze
May 03, 2013 | Refrigerators
I have a Kenmore Elite front loader model 42198900 , this morning shut the door ,light stayed on and no power to controls, any ideas
Did you ever get an answer to your issue? I am having the same problem. The light stays on when the door is closed and no power to the machine. I have unplugged it and done some other things to no avail. thanks
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Kenmore Elite gas dryer, 10 years old. Even though door closes easily and securely, the light stays on and the dryer will not run. Despite simple efforts to make sure that the door is secure and all...
The door switch has broken...
that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 29, 2010 | Kenmore 72972 Gas Dryer
I have a Kenmore Elite stainless steel three door refrigeator I bought it oct 07 at sears. This am I got up opened the refrigerator door and it was hot inside I think maybe the door was ajar over nite can...
Do you recall if the door opened easier than normal that morning? its possible, but not likely, that the door was open, but its kind of hard to make those frech doors stay open even partially. you may have a bad light switch not shutting light off. is any of the plastic around the light bulb melted?
I have to think its something with the light bulb, since you say it was hot inside. thats a far cry from the not really cold i normally hear from my customers.
some french door fridges use a sort of finger mechanism located at the top outer corner of doors, if this breaks, the doors might not close easily by themselves, or worse, not stay open. without personal inspection, i cant give definitive answer
Mar 01, 2010 | Refrigerators
Door sensor is not working, inside light stays on
This may be a simple switch with corroded contacts. Try this:
Locate the button that controls the light and depress it fully, then let it fly out, snapping it several times to see if it will clean itself up.
If not, it will have to be replaced and this with varying degrees of difficulty depending on how it is mounted.
Since it is a Sears brand appliance, go to the Sears parts department on line and enter your model number. Nearly all Sears/Kenmore appliances will be listed (among with many other brands) and there will be an exploded line drawing of the device that will help you locate what must be removed for this replacement. You can also order that part while you are there if you decide to replace it yourself.
Feb 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refregerator lights on/burning even doors are closed
If I understand correctly, you have the bottom freezer with the two doors that open into the fresh food section. Also you have to open one of the two doors first in order to get into the fresh food section. If i ma correct. The switch on the door you have to open first to get into the fresh food section is bad. This is why it makes not difference if you hold both in. The switch on the second door does something else. You will need to replace the switch that the first. You can test this switch by, take the switch out. They are tricky to get out. Take a putty knife and slide it under one end of the switch, push in while you are prying outward. It should pop out. There should be three wires going to the switch. One of the wires is hot (110 Volts), one goes to the fan inside the fridge and the other goes to the light. (The switch operates like this. When you close the door, it turns the light off and the fan on. When you open the door, it turns the fan off and the light on.) Once you find out which one is hot, connect one of the others to it. If the fan comes on try connecting the hot to the other wire. The light in the fridge should turn off. If so replace the switch. I hope you can understand the way I tried to explain.
Please rate solution
Sep 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
