Question about Garden
Why did my polaris magnum spark plug blow out while riding
    Top Expert:
  • 14,161 Answers
Posted on Feb 23, 2016
  • 38 Answers
SOURCE: I Have a Polaris 500 4 x4 Magnum and the Fan keeps
check your rad cap
Posted on Oct 02, 2009
SOURCE: I have a 325 magnum polaris 2000 i have no spark
i have no spark on the plug on a 325 polaris
Posted on Mar 30, 2010
kapishtech
  • 2272 Answers
SOURCE: 2002 POLARIS 325 MAGNUM 4X4
You need to look at the wiring block. Check for 12v source at the red/white wires with the key switch on. The red/white wires are always hot with the key on. If not check your key switch.the quick connect at the kill switch/reverse override box .Also check the power to spark plugs.The spark plugs get power from coils to spark.If there is no power to spark plugs and coils are ok then its faulty spark plugs it self or faulty connection between spark plug to coil pack. try unplugging the black wire from the CDI .Then check.If still no spark then its faulty cdi.Get it checked. Also check if there is gap got created between between the floorboard and the clutch cover . the covers sometimes will sag or melt a bit and get against the drive clutch or the transmission pulley.
causing it to drag when you try to start it. that could be the problem.
also look for any wires that may be resting against the cover.
you may have a short that makes contact and by moving the cover you move the wire.
the clutch runs independantly of the transmission.
once you give it gas the engine spins faster and the clutch draws in tight against the belt causing the transmission to turn.
the clutch and the crank are balanced together.
you could yank the cover and make sure there is no visible damage to the clutch itself.
Also check the motor mounts.They aren't very large and wear out easily letting the engine sag and could cause it to get against the clutch cover.But also because moving the cover moves the engine a littls it could be a loose connection.If it starts by lifting the cover, get down and lift the cover and look to see what is moving around the engine when it moves. check all of your wire connections. The other thing to check is,that check that fuel is flowing freely and running properly through the pump.If its low if no fuel running to the pump then its the cause of faulty fuel pump or fuel blockage.Get it checked and cleared.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
  • 123 Answers
SOURCE: Where are the cam timing marks on a polaris magnum 1998
There will be a couple sets of timing marks for your cam. The first and probably most important is the mark on the flywheel. On the top of the recoil cover, there is a bolt that can be removed to see the timing mark on the flywheel. The mark on the flywheel will be a "T". You will notice that the threads where the bolt was removed will have a point, kind of like an arrow that the "T" needs to be lined up with. Next there should be 2 dots on the camshaft gear. If the "T" is in the window, the dots should be at the top of the gear, and the piston should be at top dead center. The camshaft lobes will also be facing away from the valves. Hope this helps, Daniel.
Posted on Nov 04, 2011
firefight569
SOURCE: 2x4 polaris 425 no fire to the spark plug
Yes it does
Posted on Jan 21, 2012
Where are the fuses on a 2001 Polaris 325 Magnum 4X4
Polaris 325 MAGNUM 4X4 HDS A00CD32FA Parts Manual
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA
View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
Aug 07, 2015 | Polaris ATV
My Polaris Magnum 325 won't start
The coil could be bad. That's the thing that the plug wire goes into at the other end of the plug.
Nov 23, 2013 | Polaris ATV
Lights on 1995 Polaris 4x4 magnum worked b4 changing of spark plug now they do not. is there a fuse 4 the lights if so where is or r they located? if not a fuse then what everything else works fine
There is a fuse but I am going toward the little plus that go's to your light that may have come unplugged when you changed your plug. That a bit old look for inline fuse or under the seat?
Oct 01, 2013 | Polaris ATV
Where is the voltage regulator located on the 2005 polaris 330 magnum 2x4?
2005 Polaris 330 4x4 will not go in 4x4 unless i press an hold the over ride button. an what dose the ( E ) stand for on the speedometer ... like it should say ( H.L.N.R.P) any ideas
Jul 30, 2012 | Polaris ATV
Polaris 325 magnum spark plug change
The spark plug is on the left side (shifter) of the head,,..?/ this is August.. if the atv has been sitting the carb may need a qualified professional to clean it again.. Replace the spark plug before you squirt anything in the engine...
Jul 27, 2017 | Polaris ATV
My polaris 500 magnum was running fine and it just cut off , has gas and a new battery , turns over but will not start
Check the unit for spark, I use a new spark plug and just disconnect the plug wire from the one installed and ground the new one to the head or block and then crank it over to see if it has blue/white spark at the plug electrode. If not make sure the kill switch/circuit is functioning properly. Check the spark coil leads to make sure the wires are intact. I would also check to make sure voltage is present to the cdi pack and that the wires are secure.
Dec 11, 2011 | Polaris ATV
330 Magnum bogs down.
NO! Check the boot between the carb and engine. Very common problem for aged rubber is non-visual cracks. Pull it off and check the boot by kneeding it and looking at it under a light.
Jan 15, 2010 | Polaris ATV
Nov 11, 2009 | Polaris ATV
Cut off switch in kill position. Ignition switch defective. Low battery. Bad CDI ignition module.
Jul 06, 2009 | Polaris ATV
Garden Logo
318 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
