Question about Kitchen Ranges
I had every burner on high and the oven on( i was trying to heat the house) then everythig shut off all at once...the clock still works?
  • Kitchen Ranges Master
  • 2,842 Answers
Propane or nat gas ?
Posted on Jan 04, 2009
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
We recently moved, when we got to our new house we plugged in our stove. We turned on the burner and it didnt work, we tried the other three and they didnt work either.. Finally we tried the oven but there...
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
Feb 07, 2011 | Amana Kitchen Ranges
My stove does not work
Sounds like you have a voltage problem. try slamming your double 40 amp house breaker on and off 2 times. then try your stove out and see if that worked:)
Mar 12, 2010 | Kitchen Ranges
Stove/oven not heating up after replugging in.
Power supply is most likely burnt. It has capacitor's inside that will fry and overheat. last possible cause would be faulty control panel.
Oct 06, 2009 | Frigidaire FEF336BC Electric Kitchen Range
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Burners not working and stove only heating up to MAYBE 100 degrees
Had a similar problem...it was the power coming into the house and the ground wire was badly connected. The power company checked out the lines feeding the house and discovered the problem. Its caused by the fact you are trying to heat the stove with only one line...when, you need two. Check the house circuitry.
Jul 16, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Cook top
Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
May 28, 2008 | Frigidaire Cooktops
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
