Question about Brother MFC-440CN InkJet Printer
Problems with the brother MFC-5440CN printer. Showing the following: Unable to clean Troubleshooting and routine maintenance in User's quide. It's a 1yr old printer. Thank you cheers Jovanka
  • 2 more comments
  • jovankal01 Jan 04, 2009
    If I try to press any buttons the message appears that one I've mentioned above.Unable to clean and the rest.
  • htcogic Jan 29, 2009
    I have the same problem. Machine keep saying unable to clean. This machine is a piece of junk. I will never buy a brother again!
    alvinp1
  • philipraymon May 02, 2009
    message says unable to clean how do i fix problem
  • Juanita Vega
    Juanita Vega May 11, 2010
    can you explain a little more of the problem your having
  • 685 Answers
Ok have you tried to unplug it to reset it?try this and if doesn't work then we will try something else
Posted on Jan 04, 2009
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Unable to clean-see troubleshooting and routine maintenance chapter in user's guide. . .nothing happens when I do what the guide says
I have a MFC-420CN. If you have followed the guide and have no results, you can call Brother Customer Service : Canada 1-877-2768437 or USA 1-800-284-4329.
Apr 02, 2012 | Brother MFC 420CN All-In-One InkJet...
I have a Brother all-in-one printer MFC 420CN and it displays unable to clean...see troubleshooting and routine maintenance in user's guide. Itried turning off and back on but it does not reset...
Try this and see if it works... It works for my Brother MFC-6490CW and I am sure the same process probably will apply to your machine. If it doesn't contact customer service and let them know you need to know how to Power Purge your machine. Good Luck!
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Jun 04, 2011 | Brother MFC 420CN All-In-One InkJet...
Unable to clean See troubleshooting and routine
the porous pad in your printer need to be replaced and the ink counter need to be reset... you will need to go into the service mode to reset the waste ink counter
Feb 18, 2010 | Brother MFC-5440CN All-In-One InkJet...
Unable to clean see user's guide troubleshooting and routine maintaince chapter in users guide
Follow this instruction:
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Oct 01, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to print See Troubleshooting and routine maintenance chapt
Open the top cover and hold the interlock switch on the top right hand corner. Power up and wait for the carriage to come to the center. Shine a flashlight all the way to the right and left and pull out the crumpled paper. You should be able to print again..
Aug 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
BROTHER MFC-5840CN "UNABLE TO CLEAN"
If you go to this page you can download the user manual right from the Brother website: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000075/MFC-5440CN_UsaEngUsr_D.pdf
May 27, 2009 | Brother MFC-5840CN All-In-One InkJet...
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-440CN InkJet Printer Logo
209 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
