Question about LG Washing Machines
My lg wm 3632 display error IE
MY LG WM3632 DISPLAY ERROR IE DONT STAY LOUNDRY CYCLE
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Posted on Jul 16, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM-2032HW front loader
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Posted on Oct 02, 2008
canbruce75
  • 1776 Answers
SOURCE: IE error code
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 25, 2009
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
Lots of IE messages, water not loading into washer before cycle
'IE' for LG washers means 'Inlet (water) Error'.
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call to confirm that it is not something else like the control board which is not controlling the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 24, 2011 | LG WM-2277HW Front Load Washer
Ie error on a new washer
ie error means inlet error inlet valve might be busted or tap might not be turned on or kink in the hose.
Jan 05, 2011 | LG WM-2277HW Front Load Washer
IE error on LG intellowasher
IE = Inlet Error. Turn off supply valves to hoses and remove hoses from back of machine. Pull inlet screens out of the washer where the hoses were previously attached, clean them out, and re-install. That solves the IE problem about 95% of the time. (Usually, you only have to clean out the cold one.)
Jan 02, 2011 | LG WM-1290FHB Front Load Washer
Lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Jul 17, 2009 | LG WM-2277HW Front Load Washer
LG WM-2032HW front loader washer gives error goes OE and IE
Oct 02, 2008 | LG Washing Machines
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
24 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
