Question about Sewing Machines
Arrow r-20l how to thread sewing machine - Sewing Machines
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 139 Answers
SOURCE: How to thread the Singer Sewing Machine Ser NO 1507 ZHV 826606183
You can find Singer threading diagrams at http://www.singerco.com/resources/threading.html.
Posted on Apr 16, 2010
Threading the machine
You're machine should have a simple layout in arrows from the thread spool along down to the needle.
Apr 24, 2017 | Sewing Machines
How to insert sewing thread from the begginning to end
There should be arrows directing where the thread should go placed strategically around your machine. Your manual should have a diagram showing how your particular machine takes thread. Watch a YouTube video about threading...just about every machine does it in the same way.
Feb 01, 2017 | Sewing Machines
Show do I thread the euro shark 60?
I believe it's on the right side back edge of your machine facing you, most machines have arrows printed on the machine for the direction the thread is to be threaded.
Feb 15, 2015 | Euro-Pro Shark 60 - 384
How do I thread my machine
Please post the make and model of your machine to get the threading information. For most standard sewing machines (not sergers) with the thread mounting on the top right or behind the right side of the machine, the thread will be routed from right to left and then down then up and down to the needle. The specific model will determine the details. Some machines will have arrows indicating the pattern.
My Singer sewing machine (an old machine from ~1968) has several spots where the thread needs to be wrapped around a guide to correctly route the thread. In other spots, it just goes straight through the guide. The Touch 'N' Sew machine has the threading diagram on the inside of the swing out cover on the left side of the machine.
Oct 15, 2014 | Sewing Machines
How do you thread sewing machine
Do you have a manual? Or can you see the arrows on the front of the machine? Nearly all machines thread the same way.
Aug 17, 2014 | Husqvarna Husky 145
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
How to thread a singer promise sewing machine
Look at the Arrows on the machine. Follow the arrows. Just make sure you do this with the presser foot UP.
Dec 29, 2012 | Singer 2259 Sewing Machine
I have an arrow m23 deluxe sewing machine im haveing alot of trouble getting any info on it i really need a threading diagram please can you help!!!
Arrow is not the actual name just a name for the machine, if you can email a picture I can tell you the equivilent model drivewithken@blueyonder.co.uk
Feb 25, 2010 | Sewing Machines
Lost manual need help in threading machine
Thread it though the tension then the take up lever then the needle. I think your machine has numbers and arrows showing you which way to go.
sewman7
Apr 30, 2009 | Sewing Machines
Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Apr 26, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
