Question about RCA F27450 27" TV
On my RCA model F27450 does not have any sound.
From what I can read in the manual, I need to get my Fixed Output, Speakers On but how?
  • 318 Answers
The output of an amplifier sound pass through a jack. this jack has a change over contact springs.
also test the speaker resistance.
also check the AV cables resistance.
Posted on Apr 30, 2009
Does RCA model F27450, made in November 2002, have a digital (atsc) tuner?
Doubtful. That's long before digital broadcast was implemented. You will need an adapter box.
Sep 09, 2014 | RCA F27450 27" TV
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I have an L37HDTV10A that i just replaced the main board...i get picture but no sound...everything looks connected inside...also, what remote do i need?...will a universal work?
Go into ur tv Menu goto OPTION go down to Output Select,press enter make sure selection on (Fixed).This fixed selection will pick for the tv out put to tv speaker.Tv should have sound now on it speakers.Try website like to buy the tv original remote work for the best used for to reajustment setting and setting on the tv Menu.
Jul 29, 2011 | Vizio L37 Television
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
Im tryin to hook up my rca dvd home theater system so we can also get the sound from the tv to the speakers
Assuming (since you don't identify them) your RCA has at least one available analog stereo input and your TV has a analog stero-only output, just connect them with RCA cables, set the TV's output volume (if it has menu item for it) to FIXED so theTV volume doesn't affect the output, select the input on the HTS and you're good to go.
Another way might be to take the TV-related audio from the cable box straight to the HTS in whatever manner is the best quality. Digital would make mulitchannel audio possible.
Or name the devices involved, find the manuals and read up on your applicable options.
Feb 04, 2011 | RCA Audio Players & Recorders
No audio RCA F27450 27"
this is a very old problem.
dont break that tv. the amplifier is not working.
change the audio amplifier IC in your tv
Dec 09, 2008 | RCA F27450 27" TV
Picture size
I called RCA about this and first was told that it was my cable company till I told the rep that it does this even when I unhook the cable. I was then told that I could take it in to get it fixed and that even it it was a bad part on their end that I could end up paying for it as if might be the pictue tube or the screen. Guess this will be the last RCA that I ever buy again.
Oct 22, 2007 | RCA F27450 27" TV
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
RCA F27450 27" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
