Question about Raypak Pool & Spa
What is hlv sensor code mean on a raypak 2100 digital gas heater
    Top Expert:
  • Raypak Master
  • 8,686 Answers
High limit check gas pressure if ok burner tubes for debris
Posted on Jan 09, 2018
  • 22 Answers
SOURCE: raypak 2100 digital heater give fault code eol
ILO or ROL. There is no EOL.
ROL is a switch inside the lower left corner of the heater. Press the red button. ILO is a lockout. Power down and power up.
Posted on Dec 21, 2008
johnsonr1
  • 91 Answers
SOURCE: What does SMS on digital screen mean?
I believe the code is SNS which is sensor failure. It thinks your pool water is either above 110 degrees F or below 36 degrees F. Post the exact model/serial and will assist you further. The sensor is not expensive and somewhat easy to change if you are mechanically inclined. If not, I would strongly advise you to call your local mechanical contractor to service this boiler and it does not have to be a pool company, it can be your furnace contractor. Or let me know where you are located and I can recommend someone from that area.
Thanks
Richard
Posted on Jun 23, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
john224
  • 1378 Answers
SOURCE: last season raypak 2100 heater would light but
Thank you for posting your question here on Fixya.com.
Along the manifold there will be several gas ports feeding gas into the burner tray tubes. The tubes are the narrow steel tubes that extend under the heater from the gas line. We use a piece of #12 solid wire and run it in and out of the tubes from under the manifold. Spiders like nesting in the tubes and their silk blocks the gas flow. Once the gas migrates over from further away from the pilot you get the 'whoosh' of ignition. As you clean the tubes and recheck the heater be sure you pay attention to the flame color. Anywhere you see orange flames above a tube you need to shut down and then clean the tube. Orange flame means poor combustion and needs to be fixed to prevent sooting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 10, 2010
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
John
Posted on Jun 01, 2010
Raypak 2100 206A worked 3-4 times after replacing circuit board, now error code GVO, gas valve open, what does this mean and how do I correct it?
check to see if you have proper gas pressure at unit most people think its the unit but mostly it is too small a gas line or too small gas meter call gas company
Jul 07, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
49 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
