Question about Dishwashers
Kenmore 18 inch dishwasher 587.14349690 - Dishwashers
3 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: need owners guide for 18 inch Kenmore diswasher model 14432/14439
Source => http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Kenmore Customer Care tells you to go to this site for free owners manuals =>
ManageMyHome.com or http://www.managemyhome.com/mmh/
I found and owners manual and installation instructions there. I wants you to provide an email address.
Posted on Jan 03, 2009
localwonder
  • 6784 Answers
SOURCE: 18 inch dishwasher does not have any water
HI. This is a water inlet valve issue. I recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. Replace the valve if it fails the test.
Posted on Dec 28, 2009
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
18 inch dishwasher
I've never heard of dishwasher salt. 2 kg is about 4-1/2 pounds worth.
May 06, 2014 | Dishwashers
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
I have a 17 - 18 inch dishwasher and the water runs out before the wash cycle is over. If I have not used it for a while, when I open it there is water in the bottom. What am I doing wrong??
I think your drain hose must be too low...the drain hose has to raise above the bottom of the sink..this keeps a air gap in the hose.. keeps the water from running out and will also keep water from the sink running into the dishwasher... let me know if this helps
Sep 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Draining water on kitchen floor
I am not familiar with your model dishwasher, but had a similar problem a few years back. I am assuming you have checked the obvious causes, such as a worn, or damaged gasket around the door. My problem was fixed by replacing the lower spray arm. The spray arm is a couple inches wide, about 18 inches long, has holes in it and rotates as it dispenses water - some lift up during the wsk and rinse cycles. In my case some of the holes got plugged up with gunk, which resulted in the water shooting out harder and further from the other holes. Those streams of water went places they were not designed to go and ended up on my kitchen floor. So check that part out and see if it is the cause of your problem. Good luck!
Mar 21, 2009 | Kenmore 46462 Front Load Washer
Leak under door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
s7657usut
Mar 07, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Need owners guide for 18 inch Kenmore diswasher model 14432/14439
Jan 03, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Width of dishwashers seem standard but my bench space will not take standard size. Is there any brand which makes a narrower model.
Try Bosch/Siemmons they seem to be about 1 inch narrower than my last one. Most brands also make an 18 inch model. It usually has to be ordered as most places don't stock them. But they are fairly common. I know Kenmore, Frigidaire, Haier and lots of others make 18 inch models.
Jul 04, 2008 | Dishwashers
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
