Question about Electrical Supplies
Wiring diagram for Cutler Hammer O drum controller No.5441H27A
  • 2692 Answers
SOURCE: hooking up generator switch panel
On a residence, the ground bar and the nutural bar may be hooked togethervia a ground screw on the case.    In that case it matters now which side you use for the nutural and which for the grounds. Just make sure to keep all of the whites on the white side and the greens on the green side.
Posted on Jan 11, 2009
gotgeek2
  • 565 Answers
SOURCE: need wiring info for cutler
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Posted on Jan 29, 2009
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
mydogisk
  • 50 Answers
SOURCE: cutler hammer a10ano series a-1 contactor
There should be 2 contactors for forward and reverse. you have to wire them so that the power coming in will switch 2 opposite phases to reverse.
Posted on Apr 10, 2009
  • 66 Answers
SOURCE: 20 AMP Cutler Hammer CH GFI wont fit in the breaker box
It will fit, the extra bump out on the back makes it a bit harder to hook the back locking tab before you push it on the bussing. Also, make sure no wires are in the way obstructing the bump out since it hangs out further than the standard breakers. The most common problem is the bump out making it hard to hook the locking tab onto the outer rail. Make sure the breaker is in the off position, then try holding it more flat as you insert it keeping it close to the bussing. This will help keep the extra bump out from obstructing the locking tab from hooking the back rail. Once it's hooked on the back rail you can push it on the bussing like normal.
Posted on Oct 10, 2009
How To wire a cutler-hammer A/C Disconnect Box 60amp-240V Non- Fusible
"LINE" is typically the incoming power.
"LOAD" is typically the outgoing wires to the machine.
Sep 19, 2014 | Cutler Hammer DPU222RGF 60 Amp Out A/C...
Have a cutler-hammer 210 responder drive inside the box is a relay marked NJ it is going bad how do I find the # to replace it THANKS
There should be information on the relay itself. Boettchers in Beloit handle Cutler Hammer (Eaton) products. You may be able to pull the relay and take it to them for an exact replacement.
Feb 17, 2012 | Cutler Hammer Electrical Supplies
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
Wire diagram for fusible pullout a/c disconnect.
THERE IS ONLY THE WIRES GOING IN AND THE WIRE GOING OUT THAT IS HOW THIS WORKS
Jan 07, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
Need a wiring diagram for a cutler hammer 100 amp double throw safetey switch the box came with no manual
Line voltage (source power) goes to the lugs on the top and load (goes to the device) is on the bottom. If it is designed for single-phase power (with a neutral), there should be an isolated block with lugs for neutral, but if it is not, just get an inline lug (available at a hardware store like Home Depot) to connect your neutrals and then insulate it with electrical or rubber insulating tape. Then you will need to bond your grounds (from the source AND to the device) to the can.
Nov 06, 2009 | Cutler Hammer Electrical Supplies
CAN A EHD1020 CIRCUIT BREAKER (CUTLER HAMMER) BE USED IN A 120/240 APPLICATION? BREAKER IS IN A SFDN100 ENCLOSURE (CUTLER HAMMER)
For 240 if it is a single pole breaker then no. You need a double pole breaker or 2 single breakers , one above the other, connect the red wire to one and the black wire to the other. this way you are drawing from both legs. hope this helps you...
Sep 15, 2009 | Cutler Hammer Eaton Electical #BD3030...
I have a c25 relay I'm wiring that is controled
I am a Master Electrician, I provide DIY services via email. You can pay via paypal. email me at buffalonymann@yahoo.com and I'll give you the link to my website where you can set up the account
Sep 04, 2009 | Cutler Hammer Eaton Electical #BD3030...
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
Jan 29, 2009 | Cutler Hammer Cutler-Hammer No.BR48L125RP...
Electrical Supplies Logo
348 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
