Question about Emerson MW8107WA Microwave Oven
Fuse problems. Where can I can find the fuse for the Emerson MW8107WA? or do you know a website that sales fuses for the Emerson MW8107WA? Thanks, RS
  • Emerson Master
  • 9,149 Answers
Microwave fuses are usually located inside on the floor of the chassis behind the control panel or on the door switch mount between the switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you do need a new fuse, it will be a 15- or 20-amp ceramic fuse, and they are available at local home centers, home improvement stores, hardware stores, and appliance parts stores.
Posted on May 17, 2007
Emerson MW8168B microwave fuse
Good job, and thanks for passing along the information.
Aug 31, 2012 | Emerson MW8168B Microwave Oven
How do you check/change the fuse in the microwave?
You will need to remove the cover which opens from sides and pull it up. Follow where power cord comes in and before it get tothe transformer,there will be a fuse.
YOU MUST DISCONNECT POWER AS PART OF YOUR ELECTRICAL SAFETY!!!
Sep 22, 2011 | Emerson MW8107WA Microwave Oven
How do you replace the fuse in the microwave?
If you are hand enough you can take the top cover off and follow the incoming power cord. Before the huge transformer there will be a fuse.
YOU MUST DISCONNECT POWER AS PART OF ELECTRICAL SAFETY.
Microwave seems to not be getting power, I tried difference electrical outlets. Is there a fuse that could possibly need changed?
Yes there is internal fuse inside the system. If you are hand enough you can take the top cover off and follow the incoming power cord. Before the huge transformer there will be a fuse.
My microwave just went out,plug it up and it doesnt come on
You might have blow the internal fuse. If you are hand enough you can take the top cover off and follow the incoming power cord. Before the huge transformer there will be a fuse.
Sep 15, 2011 | Emerson MW8107WA Microwave Oven
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
Where is the fuse
remove the outer cover and the fuse is either on top or on the side in a fuse holder clip,it takes a special "ceramic-fuse" available at hardware stores, if it blows again.suspect a h.v. capacitor,diode,magnetron, or exposed wire arcing
Apr 19, 2010 | Emerson MW8107WA Microwave Oven
Mircowave oven
CHECK THE PROBLEM ON THE BURN THERMAL FUSE ON YOUR UNIT.
Aug 16, 2008 | Emerson MW8107WA Microwave Oven
Emerson MW8107WA Microwave causing apartment fuse blow
It seems that something within the microwave must have fried in the power supply unit. This should not be a very expensive repair, However, get a technician t take a look and give you a rough estimate before you decide to repair.
Dec 17, 2007 | Emerson MW8107WA Microwave Oven
Emerson MW8107WA Microwave Oven Logo
174 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
