Question about Samsung " 30"" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel FTQ387LWGX/XAA"
Samsung electric range FTQ387LWGX Range display does not display unless burner is on.
Samsung electric range FTQ387LWGX Range display does not display unless burner is turned on. It then displays all items for 5 seconds and clock needs to be reset. Even though controls seem to work, nothing heats up. Turn off burner and display, including clock goes blank. Have turned off breaker to reset, but problem continues when breaker is back on.
MicrowaveSvc
  • 9047 Answers
SOURCE: Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Posted on Oct 19, 2008
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
sWatti
  • 188 Answers
SOURCE: Samsung Sync
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!!
But you can try following steps to get rid of it:
  1. Takeout the battery of your phone.
  2. Leave your cell in air for a day or two without attaching battery and battery cover to it.
  3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
Posted on Nov 24, 2009
SOURCE: my SyncMaster 710N comes on for only a few seconds
I just had same problem.Did you find any solution? Please write to me on koridor10@gmail.com
Posted on May 28, 2010
  • 11800 Answers
SOURCE: Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Posted on Jun 26, 2010
Testimonial: "Thanks, Azraelsrl! "
Samsung range FE-R300SB burner wont adjust
Yeah replace the burner control, they have universl fit control knobs at most local appliance dealers.
Jun 02, 2014 | Samsung RESF3330D Electric Kitchen Range
I was preheating my Samsung ftq387lwgx oven and heard 3 loud popping noises. Shut it off because it scared me. Turned it back on and it doesnt heat up and the top burners don't work either. The clock...
It sounds as if the oven element short circuited and blew one of the internal fuses in the range. If this occurs it generally knocks out the oven circuit and two hotplates. Locate the fuses, they are mostly in the griller/broiler section. Sometimes they are in the back of the range. Replace fuse wire and power will be restored. Before you turn the oven back on carry out a visual inspection of the element for holes/blow marks. It this is the problem the element will need replacing.
Feb 18, 2011 | Kitchen Ranges
I have samsung ceramic top range and the inner burner is not working on the main multi burner. Do you know how to fix it.
Well, after only a year, my front right burner was on all the way and wouldn't lower. Samsung repaired the rheostat. Three months later, the left burner is doing the same thing. This time off warranty, even though the bill says '5 year warranty on parts.' No dice. So we may have to junk this stove. Anyone know better ones?
Dec 09, 2009 | Samsung RESF3330D Electric Kitchen Range
Replacement Range element not heating
red light means power is on in the wires. maybe the plug is very dirty, wire disconnected. if you mesured power at the connector, there is no reason a good burner would not work unless that when plugged in its not getting a good contact
Jul 25, 2009 | Whirlpool RF364 Electric Kitchen Range
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
Aug 31, 2008 | GE Spectra JBP78 Electric Kitchen Range
Samsung " 30"" Self-Cleaning Freestanding Electric Convection Range - Stainless-Steel FTQ387LWGX/XAA" Logo
53 people viewed this question
Top Samsung Kitchen Ranges Experts
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
