Question about Insignia IS-PDVD10 Portable DVD Player
Insignia IS-PDVD10 NO PICTURE
My portable dvd player was playing fine and then suddenly there was sound but no picture. Occasionally the picture will flash on the screen. I have pushed the menu button and other buttons, but still only get a flash on the screen.
  • angiemama40 Feb 17, 2009
    I have great sound, but I can hardly see my picture.
    President:
  • 814 Answers
You unit has failed to overheating problems causing the unit to expand and break the internal connection of the video processor to the main board. If under warranty send unit in for replacement.If not you must try to shrink the circuit board back to the normal position. This is a last resort fix. You should have someone experienced to open the unit and see if they can find the bad component or area that needs reconnecting. If they have the right equipment they may be able to reheat the board and straighten it while heating the board with a heat gun. you must protect all plastic parts by covering them with tin foil.You must heat the board in the specific area of the video processor or the the other failing connections. These boards have layers and the solder connections may be hidden from sight in the inner layers. After heating for a few minutes, stop heating and let the unit cool down for a few hours in a straight position. This may or may not work depending on the damage done already. This technique is from repairing intermittent computer boards and video card that have had overheating problems or have been rough handled in shipping and handling. Again i say it does not always work and is a last resort before replacing the unit.You should go on the internet and research this problem before attempting it yourself. There is on video on you tube on this very technique and it worked on laptop computer boards that had intermittent video outputs. Hope this helps you with your problem.
Posted on May 10, 2009
WHITE SCREEN NS-P10DVD11 PLAYER....Plays sounds no picture....Has a 1 year warranty...can i get a replacement..
The fault is with its video processor section. If the set is in waranty period, it will be best for you either get it repaired by its authorised service center, of replaced it by an other one. The second stated will be best, rather than get it repaired as it is new.
May 22, 2012 | Insignia IS-PDVD10 Portable DVD Player
I have Insignia PDVD10 portable DVD player. So
Press remote button audio track. That solve my problem.
Jul 04, 2009 | Insignia NS-PDVD10 Portable DVD Player
Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
I am looking for the book of instructions for the Insignia NS-PDVD10 player.
check the manufacturer's website:
http://insigniaproducts.com/
You will find the manuals in English, Spanish and French:
http://insigniaproducts.com/products/dvd-players-recorders/IS-PDVD10.html
Barely visible picture and no sound
2 things the easy fix would be the screen switch is jammed a little circle next to where the door close you will need to pry the switch out and the second fix (your backlight (inverter) is out (better off buying a new unit)
Aug 15, 2008 | Insignia IS-PDVD10 Portable DVD Player
No picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
http://ftp.freenet.de/pub/filepilot/windows/multimedia/video/k-lite_codec_pack/klcodec390f.exe
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Haier PDVD10 Portable DVD Player
Fixing the picture on the Insignia IS-PDVD10 10.2" Portable DVD Player
The player is in 4:3 mode (Standard TV mode). There is a button on the deck of the player called MONITOR that will toggle between 4:3 and 16:9 modes.
Press this button.
You can also check to screen geometry in the SETUP menu and make sure it's set to WIDESCREEN.
Jan 05, 2008 | Insignia IS-PDVD10 Portable DVD Player
No picture
No display
Check R754 (0R47). Note-this is a separate unit which comes as part of a stack system
Nov 24, 2007 | Insignia IS-PDVD10 Portable DVD Player
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Nov 11, 2007 | Insignia IS-PDVD10 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
136 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
