Error 0x000005b3 When installing the above canon printer on a Windows 7 64-bit machine, after completing what seems like most of the installation, I get the above error.
Guru Guy
  • 95 Answers
SOURCE: Installing Panasonic DP-4510 to Windows Vista
Crafties is correct, most of the print drivers loaded onto the discs that comes with copiers were developed a few years ago. Try Googling "Panasonic dp4510 print driver vista" and see what you get. If one comes up listed under www.b2b.panasonic.com, go to it because its straight from Panasonic. I always have to search for the drivers for Vista on a new install.
Posted on Nov 16, 2007
  • 96 Answers
SOURCE: kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Posted on Jul 21, 2008
  • 67 Answers
SOURCE: Canon c3220 won't print after new drum installation...
this error reoccors when one or more drums are damage or reach their end it is best to replace all the drums since they tend to go all at the same time almost
Posted on Aug 19, 2008
SOURCE: C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Posted on Jan 10, 2009
  • 413 Answers
SOURCE: driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
Posted on Apr 25, 2009
Canon LBP-810 Printer drivers for windows 7 64 bit os
I checked the cannon website and it appears that they do not support a 64 bit driver for windows 7 for that model.
LBP 810 Canon Europe
If you have windows 7 professional you could use the XP virtual machine to install the XP drivers on then share it form the XP VM. It's a bit of a fudge but it should work.
Mar 12, 2015 | Canon Office Equipment & Supplies
Canon imageclass d880 info
What OS is the Vaio running? Canon has drivers for the 32-bit versions of Windows XP, Vista and Windows 7. The Windows 7 driver may work with Windows 8 32-bit in the compatibility mode. However, most computers with Vista and later versions of Windows have the 64-bit OS; the exception are some machines that came with 2 GB or less of memory when new. Canon did not create a 64-bit driver for the imageCLASS D880. To check your OS version, go to the System Control Panel. (XP, Vista and Windows 7: Start > Control Panel (in the right hand column) > System and Security > System. In Windows 8: press the Windows key + X and do the same steps.) Then read the version information, if x64 is included then the 32-bit drivers won't work.
If you do have the correct driver installed for your OS, try swapping your data cable and changing the USB port, if in use. Do not use a USB hub but a direct connection to the computer. Check the device manager to make sure that there are no problems with the hardware drivers. (As above, go to the control panel. Then either in Hardware or System and Security choose the Device Manager. From the Windows key+X, just choose the Device Manager.) Expand the section for the type of port you are using and look for a triangle with a red X or yellow exclamation point. Try updating or uninstalling the driver and then letting the correct driver load when you reboot the computer. (Check with Sony for the driver.)
Next try uninstalling the printer and removing the data cable from your computer. Then install the driver from http://www.usa.canon.com/cusa/support/office/imageclass_copiers/imageclass_d880/imageclass_d880#DriversAndSoftware . Then connect the printer to the computer when prompted to do so. Failure to install the Canon software first can interfere with the installation of the correct driver.
I hope this helps.
Jan 15, 2014 | Computers & Internet
Driver download for canon printer pixma ip1300..
Here's the download website for the PIXMA Canon iP300 Printer -
http://www.siliconguide.com/drivers/device/1067/
OS Type Version Date Added File Size File Type Download Link (About) Windows 98 Driver 8.81a 2008-12-13 15.95 MB exe Canon PIXMA iP1300 Windows 98 Printer Driver Download Windows ME Driver 8.81a 2008-12-13 15.95 MB exe Canon PIXMA iP1300 Windows ME Printer Driver Download Windows XP 64-bit Driver 2.00 2008-12-13 8.86 MB exe Canon PIXMA iP1300 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 2.00 2008-12-13 8.86 MB exe Canon PIXMA iP1300 Windows Vista 64-bit Printer Driver Download Windows 2000 Driver 2.00 2008-12-13 8.62 MB exe Canon PIXMA iP1300 Windows 2000 Printer Driver Download Windows XP Driver 2.00 2008-12-13 8.62 MB exe Canon PIXMA iP1300 Windows XP Printer Driver Download Windows Vista Driver 2.00 2008-12-13 8.62 MB exe Canon PIXMA iP1300 Windows Vista Printer Driver DownloadTaking too long to download? Order a driver CD containing all of these installation files or buy high-speed priority download access. Installation Instructions To install the Canon PIXMA iP1300 Printer driver, download the version of the driver that corresponds to your operating system by clicking on the appropriate link above. A window should then show up asking you where you would like to save the file. Save the driver file somewhere on your computer where you will be easily able to find it, such as your desktop. Then follow the instructions below corresponding to the file type that you downloaded
exe (Executable File) Go to the location where you saved the file and double click on the file. Then simply follow the on-screen instructions for installing the driver.
Feb 15, 2011 | Canon PIXMA iP1300 Printer
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canons600 keeps telling me to turn on my enable bidirectional support in the printers properties dialog box
Not much to go on, but in printer properties, in ports tab, you'll see an option (second last) called 'enable bidirectional support'. Make sure it's ticked.
Rob
Feb 21, 2009 | Canon MP610 Photo All-In-One Printer
I want to ad a PIXMA MP160 to my new Windows Vista. Any problems?
If you have the CD-ROM A:
You can install the software that supports both versions of Windows Vista (32 bit / 64 bit).
- If you have the CD-ROM B:
You can only install the software for Windows Vista 32 bit version, however, you can download/install the software for Windows Vista 64 bit version from the web site - If your CD-ROM is "C" or you do not have any CD-ROMs:
Download/install the software for Windows Vista 32 bit / 64 bit from the Canon WEB page.: (select your OS) http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368#DownloadDetailAct
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
207 people viewed this question
jasbo
jasbo
