Question about Kenmore Electric Smooth Top Stove
Lost my manual for electric stove model 316402716
Lost manual need one to self clean oven
Techsim
  • 59 Answers
SOURCE: how do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Posted on Dec 28, 2008
  • 360 Answers
SOURCE: I set stove to self clean for the oven and received E1 F5 error
F5 - E1 Self clean latch will not lock.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Please tae the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Self Cleaning Feature..Lost my manual
Kenmore posts manuals online at http://www.managemyhome.com/mmh/ .
You will need to register your email first and then search by model number.
Posted on Mar 02, 2009
  • 5 Answers
SOURCE: Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Posted on Apr 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: I tried to set my self-cleaning on my Electric
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Self cleaning oven f2
How do I clean a self cleaning oven.
Dec 09, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I have lost my manual and need instructions on how to start the self cleaning for the oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 18, 2011 | Whirlpool GBS307PR Electric Single Oven
I have a UMP 404 de dietrich oven user manual
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jul 17, 2010 | De Dietrich UMP404 Powerclean Stainless...
Lost my manual. how do i clean my self cleaning Gemini double ovens
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
Nov 15, 2009 | Maytag Gemini 30" Self-Cleaning...
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Self cleaning oven
Press the cleaning button and then the up arrow that regulates the temp as if you are baking I think it reads 300 and then it starts. This is for Kenmore self cleaning
Dec 10, 2007 | Magic Chef CER1115AA Electric Kitchen...
Open Questions:
Kenmore simmer select board problem The SS button tripped my house breaker. I haven't used SS since (button is now 'off') so not sure it is working - pretty sure it is not. Otherwise, all of the stovetop elements seem to work fine. The 'Element on' light works (on when any burner is on, off when they are all off). However, none of the 'hot surface' lights work for any of the burners now. Is this just a SS board component that needs replacing? Or the whole board? I do have meters and experience to fix if someone can link me to a schematic or steps to test. Whatever happened to the SS board appears to have prevented the 'hot element' lights from working. EDIT: the model info is 790.96223409 **************************************** EDIT2: I found a schem for this; as the SS board indicator light shares neutral wiring with the other lights, is there a simple fix to disconnect one of the connections to this part of the board wiring, so that those lights will work again while I'm waiting for a new board? Pretty sure I have a bad relay on this board and will need to swap the whole board out, but I'd like to be able to check that those other indicator lights and circuits are ok so when I do get a new board, everything will work normally. ************************************** EDIT3: I rechecked the stove around lunch today; it does look like my 'hot burner' lights now work (maybe a relay was partly stuck open or shut on the board?); so, I may only need a new SimmerSelect board. I'll check for anything that looks burnt when I have the time to pull the oven out and open up the back. I did get the time to turn on each burner to 5 or 6, make sure they all got hot, and then turned down and they do all seem to regulate ok. If my 'hot burner' lights stop working again/become intermittent, I'll drop another update here. It does appear these boards are a common problem - are the relays not designed for 'hot switching' on these, and the burner switch should be completely 'off' when tripping the SS switch? That would seem to be a design flaw, if so.
Sep 27, 2016 | Kenmore Electric Smooth Top Stove
See all Kenmore Electric Smooth Top Stove Questions
Kenmore Electric Smooth Top Stove Logo
144 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
