I have a rheem furnace. A week or so ago, we had a burning smell, and the furnace shut down while I was gone. When I came back, it did start again, but the smell was still there. I called a guy who came over, found some melted wires (dont know if they were in his pocket or not before he came), and the unit worked for about four hours after he left...then there was a new sound..a chirping sound, and then the heater died a couple of days ago...I took the squirel cage apart, took the motor down, and the guy checked it, along with capacitor, and he said the motor was bad. Sold me a new motor, different capacitor (this was a 1/2 horsepower, even though the one that conked out was 3/4, but he said that because my old one had 8 amps on it, he surmized it was probably a 1/2 horse. He said the 1/2 horse was fine) I re-installed the whole thing and I get the intake blower (Or whatever it is, starting, then the red glow of the igniter, then the gas...but the fan never gets going, and the unit shuts down. I checked the wires again..called the guy, as I wanted to make sure the wiring was right. Thought maybe the capacitor might be backwards. He said it cant be backwards...would work either way...no go...any ideas?
  • 1 more comment
  • tsturdivant Jan 26, 2009
    I have a 10 yr old Rheem furnace..noticed a burning smell when the heats
    comes on goes away..does nt seem like the furnace is cycling the same..could the fan motor not be coming on...I m still getting heat if so
    could it be the capacitor
  • neilellis May 11, 2010
    He is right about the capacitor, explain what wires were on the old one and what ones are on the new one?
  • Ken Bledsoe May 11, 2010
    Where did you wire the motor to? Circuit board or fan center?
Your control board may have a problem. When the burner fires up, after a time delay of about 45 seconds, you need to use a voltmeter and see if the terminal marked H for heat has 120 volts coming off it. This voltage will be the power to spin the blower. If ther is 120 vac at terminal H then the blower motor or cap. is no good. If there is no 120 vac then you may have a bad control board.
Posted on Jan 04, 2009
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Burning laptop smell Asus x53e
The cooling fan is attached to a heat sync over the CPU. When dirt or dust collect, the fan tends to slow down and the heating becomes intense. Sooner or later, the CPU will shut down and the system will die. Clean with a can of air to remove the debvris.
Feb 26, 2014 | ASUS Computers & Internet
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
Rheem Highboy Oil Furnace runs, then shuts down. I throw in a lit paper to burn off oil residual from failed start. Hit 'Reset' button and furnace starts up. It may start up by itself for the next 3...
Oil furnaces have certain items that routinely go bad or need adjusted to work properly.Some of the common things are nozzle, then gap and location of the igniter,then last is the fire eye. You can see all of these items by pulling the burner tray out. The nozzle delivers the fuel in two ways more or less, first is spray angle then second is the rate or GPH. Nozzles are to spray an atomized mist this means no heavy droplets of fuel. If you have large drops of oil chances are a new nozzle can help you out, please pay attention to spray angle and GPH. The igniter is next, after time they will wear and you can clean the rods and reset the gap to specified distance, that being said it also needs to be a certain distance from the atomized fuel to ignite properly all very important. Then last is the fire eye it tells the furnace that a flame is established and to deliver fuel or flame out and shuts fuel down. These will build carbon deposits at times so simply clean off the deposit and clean the lens with a soft cloth and windex reposition put the burner tray back in hook up the fuel line and off you go.
Dec 20, 2010 | Heating & Cooling
I plugged mu T30 KU-2367 in power outlet, cam on
I'm sorry but by what you have explained you will need to take this machine to a pc repair store and have the AC/DC adaper on the laptop itself checked out just in case it has burned out. Also you have to have the power supply itself checked just in case feed back has damaged that too.
If you feel like doing this yourself you will need a mulimeter to test the voltage coming from the power supply and the adapter on the laptop motherboard.
Also, if this has just happened then leave the unit to cool down and try again as if the cooling fan has seized then the laptop will automatically shut down when it reaches critical temperature.
Plesae post back if you need anymore advice.
Good luck.
Jun 25, 2010 | IBM ThinkPad T30 2366 Notebook
Heater Wont light
If it has been off for a while you probally just have to bleed the gas line out. Shut off the gas valve at the heater and then open the union at the heater. Turn the gas back on till you can smell gas. Shut it down and close the union then turn the gas back on and try it again.
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Overheating and has "hot glue gun" smell
If the furnace is overheating you are smelling the insulation and the adhesive glue burning. Shut the furnace down and find out why it is overheating. Make sure the filters are clean. Check the blower motor and capacitor.
Good luck.....
Apr 14, 2009 | Heating & Cooling
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Electrical smell
did you recently screw or nail something to the wall?do you have the old fabric coated wires?
Feb 26, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
