Question about D-Link Televison & Video
How do I get the volume on the Boxee Box to increase. Remote only seems to mute and unmute and the sliding bar is at the bottom, doesn't seem to be any way to increase it.
4 Suggested Answers
SOURCE: My firmware update on my Boxee messed up the device
The good news? This is the worst problem the Boxee has and won't cost you much of anything in terms of time.
The bad news? No bad news! The Boxee rules!
Your first step is to download the most recent firmware update from the official Boxee website to your computer, saving it on your hard drive. Following that, insert a USB flash drive, copy the file, and power down your Boxee box while keeping it plugged in. Following that procedure, press and hold the power button for 10 seconds until the device turns on. You will then choose to enter Recovery Mode and select "Update From USB" in order to download the most recent version of the firmware.
If that does not work, leave your device turned on, enter the "Settings" menu, select "System", and go to "Advanced". From there you will be able to clear the Media Info Database and resolve any issues you may be encountering with scanning problems.
The final (and least desirable) fix is to enter back into "Recovery Mode" and perform a hard factory reset. To do this, you will select "Reset All Settings" and then select "Factory Reset". This will wipe your Boxee of all its data, forcing you to update the firmware via the USB flash drive procedure we mentioned above.
Posted on Mar 13, 2012
SOURCE: Why does my Boxee consistently freeze?
Hi Cory, this definitely sounds related to the firmware updates that Boxee pushes out every so often. You'll be fine in no time.
First go and grab a computer and download the most recent firmware update from Boxee's website. Now go and copy the file on a USB flash drive and power down your Boxee box while keeping it plugged in. Following that procedure, press and hold the power button for 10 seconds until the device turns on. You will then choose to enter Recovery Mode and select "Update From USB" in order to download the most recent version of the firmware.
Still no luck? Leave your device turned on, enter the "Settings" menu, select "System", and go to "Advanced". Now you can clear away the Media Info Database and resolve any issues you may be encountering with scanning problems.
If it's not yet working it's time to enter "Recovery Mode" and do a hard factory reset. To do this, you will select "Reset All Settings" and then select "Factory Reset". This will wipe your Boxee of all its data, forcing you to update the firmware via the USB flash drive procedure we mentioned above.
The firmware fix is the only option you have. I have to redo mine about once every 2 months. Runs like a champ for the first month, then the lag starts, then I'm having to reboot to see the files on my PC, and at about the two month mark It will just freeze mid show/movie. I've had mine 3 years now, and its still better than any other unit out there for its versatility. It just seems to have memory leak, like Win98 had
Posted on May 07, 2013
How do i unmute my nextbook tablet
You mute/unmute with the volume controller on the right upper side of the tablet. If it's muted, run the volume all the way down to zero, at which point the slash mark through the volume icon will disappear. Then you can set your volume level.
Dec 23, 2012 | Tablets & eReaders
How how do i increase the volume in the you tube?
On the you tube video widget there is a speaker icon. If you mouse over this icon it will give you a volume slider. Clicking the icon will mute/unmute the volume. If this still doesn't work then your system volume may need to be unmuted or turned up. This can typically be found in the bottom right hand side of your screen in the system tray. It too will be a speaker icon.
If no speaker icon is present then you do not have a sound device installed.
Nov 24, 2011 | IBM Computers & Internet
I dont know how to unmute my mic
Go to the volume icon (speaker icon) down at the lower right hand bottom of your screen (task bar). Double click the icon and click on options and click properties and check all boxes to show Mic volume Menu and fron there you can uncheck mute box.
May 01, 2011 | Computers & Internet
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to unmute microphone (microsoft Vista)
::Look EASIEST WAY OF THEM ALL RIGHT HERE::
[1] --> Right Click the Volume Icon at the bottom right corner of your screen [The Task bar].
[2] --> Click [Playback Devices]
[3] --> Right Click the [Speakers] Icon and click Properties
[4] --> Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback (By clicking the unmute icon, than slide the volume up to where you prefer it... Simple smile.gif I hope I was able to help someone with this... wink.gif
Dec 26, 2010 | Computers & Internet
Sound wont go on. muted but i have no way of unchecking the mute box
Go to the top of your keyboard. There is a button with a black sideways bell shape icon on it ( a speaker) (the f3 key)...probably four in from the left starting with esc. Toggle that on. It may be on the mute setting now. It should have waves coming out of it when it is unmuted. To the right of that button (two buttons to the right) is the increase volume control button, the (f5) key. Make sure the volume is up! If it is down all the way you will hear nothing and it will be also muted.
I am not sure why if you go into System Preferences (under the Apple icon) and scroll down to Sound and Output, the mute box cannot be unchecked. Perhaps using the function keys to unmute and increase volume on the top of the keyboard will help.
May 07, 2010 | Apple PowerBook G4 Mac Notebook
Change the volume in WMC doesn´t working...
If the remote control causes a visible change with the volume control display but no audible difference, there are only three possible fixes. 1.)Go to Windows "Start > Control Panel > Sounds > Advanced. Here you will find a set of several volume control slide bars each with a check box at the bottom for muting. Un-check any controls marked as muted and raise the volume to 50%. Exit Control Panel. 2.) Many P.C. speaker systems are self amplified and have their own volume controls which supercede anything you do through Windows. 3.)If the problem persists you most likely have a jack plugged into the wrong feed. Allways power OFF and ground yourself before fiddling with computer jacks.
Mar 12, 2009 | Dell XPS 420 PC Desktop
I have a Harmon/Kardon model:HK695-01,13. 2.1 speaker system. the satellite speaker seems like the are blown. Do I have to discard the whole system and get a new setup or can they be repaired? As the...
4. Your volume settings are too low or muted. Increase your volume by pressing the + key located on top of the right satellite. You can also check your volume through the volume control located in the taskbar. To mute and unmute the speakers, press the + and - controls at the same time.
Aug 10, 2008 | Audio Players & Recorders
Audio slider problem
Hi at the top and bottom of the orange bar showing sound level are two little boxes if you press top box sound increases press lower box sound goes down, it might help if you use the stylus.
Hope this helps
May 22, 2008 | Archos 605 WiFi Digital Media Player
Televison & Video Logo
115 people viewed this question
Top D-Link Televison & Video Experts
David Payne
David Payne
Are you a D-Link Televison and Video Expert? Answer questions, earn points and help others
