Question about Pool & Spa
Looking for a flowmaster xp2 made by aquaflo model 07826787-2 with emersom motor hp 5.o model r63mwdma-175
5 Suggested Answers
  • 8404 Answers
SOURCE: Just wondering what the flow
There is no way to know the flow rate of your installation beyond a guess ... I guess you are pumping about 95 GPM with a 2.5 hp motor ... a 2 HP moves about 75 to 80 GPM. A 1.5 moves about 60 to 80. There are lots of variables least of which are accessories in the line ... chlorinator ... heater ... filter and its cleanliness ... etc. Other vairables include pipe size ... distances water pumped, number of turns - fittings - restrictions, etc. To get a good idea of the flow rate (important to know when calculating 'turn over' rates) get and properly install a flow rate meter.
Thanks for your interest in FixYa.com
If you found this information helpful, the courtesty of a positive vote will be appreciated.
Posted on Aug 29, 2010
john224
  • 1378 Answers
SOURCE: i need to purchase a stationery switch for a
What is the serial number that goes with the motor model number? I am assuming the 06-620390-2 is off the motor; if not please also add the motor brand and model number as well.
John
(P.S. for a faster response please send this information thru our website at www.arrowmotor.net using the contact feature)
Posted on Dec 27, 2010
adamh294
  • 310 Answers
SOURCE: My Spa needs a new pump. A Max E Pro Pump 2 speed
Yes, and I recommend and install them. Look at the voltage and Amperage information on both as well. It is typical to see 220V @ 12.9 amps. If you find this on both motors, they are the same size anyways.
It would take a while to explain, but motor manufacturers can rate a motor @ 1.5HP or 2HP and it can be the same motor. They use a rating called a "service factor" to screw around with the actual HP of a motor. But even if the 1.5 is a 1.5, it would be sufficient.
Posted on Jan 11, 2011
Testimonial: "This is very helpful but I just was told that because I have an in the ground hot tub the Aquaflo would not work. It needs an outflow? Please comment"
  • 368 Answers
SOURCE: My Flowmaster XP2 will start
If it hums and quickly shuts off but doesn't turn then it is often caused by a bad capacitor. It might also be caused by something stopping it from turning. If it turns and then shuts off then there could be shorted windings in the motor or too much friction in the motor or pump. I hope this helps.
Posted on Aug 13, 2011
Flow master XP2 by aquaflo for spa; it clicks, but does not start. I could turn the shaft with a wrench, all plugs work.
the start switch has trash in it , use compressed air and blow out the back of the motor, this works most of the time for me. otherwise the motor will need to be dissembled and can be tricky do to easy to break parts. search your area for your local pool pump motor repair guy with free testing. and ahve him clean the switch
Sep 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Remove a wet end from a aquaflo xp2 spa pump motor how do I do this
There are 4 bolts that go all the way through the motor and thread into the wet end.
The first place to start it to remove the face plate of the wet end exposing the impeller.
The impeller is threaded onto the shaft of the motor.
Take a big flat head screw driver and put it onto the end of the shaft of the motor and hold it tightly so you can unthread the impeller off the shaft of the motor.
Unthread those four bolts that go all the way through the motor.
You are done at this point.
US Parts Center
Jan 19, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My Flowmaster XP2 will start and then immediately shuts off. Any suggestions on how this might be repaired?
Aug 13, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My Spa needs a new pump. A Max E Pro Pump 2 speed was recomended but I found a Aquaflo Flo-Master Xp2 Spa Pump 1.5 Hp Two Speed which is new for about $400. less. Can I use the Aquaflo model just as well?
Jan 11, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I need to purchase a stationery switch for a flowmaster xp2 model 06620390-2
John
Dec 27, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
What windings do the leads of the capasitors get attached to for the flow master xp2
Please reply with the motor brand, model and serial number so we can get you an accurate wiring diagram. Simply comment on this post and enter the information there.
John
Dec 09, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I need to replace the capacitor for a flowmaster xp2e 230v model 05825001-2. old one says 35UF +/- 6% 370VAC. is this a run capacitor? i have found replacement capacitors online that say (35) 370VAC, is...
Yes, that is a run capacitor. You will also need to clarify oval or round design.
You should take the old one in to a local electric motor repair shop if it is not obvious it is blown. Even if it is, their will be other issues that caused the capacitor to fail in the first place. You will want to try to identify those and fix them as well or you will be replacing the capacitor again soon.
John
Dec 05, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am trying to find a replacement for ann XP2
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
165 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
