Question about Dishwashers
Hello my Kenmore Elite dishwasher has both the "add a dish" and "drying" red lights stuck on at all times. The machine still works but I want to get these lights to go off!
2 Suggested Answers
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
I have a Kenmore Elite dishwasher, model #665.1392. It seems to be running okay, but the lights for the "add a dish and drying option on the cylce info panel are stuck on. They are shining red. I can&
I don't the full text of your question is here .
The full model number of your dishwasher should be on a tag covered by the door. Use it to find you user manual, parts lists and diagrams on the link below.
Searching Model For Search Your Way 6651392 21
Oct 22, 2014 | Kenmore Dishwashers
Film on glasses and dishes.using cascade complete and jet dry.Dishwasher is a kenmore elite.
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Feb 28, 2010 | Dishwashers
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Nov 16, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
1,355 people viewed this question
Top Dishwashers Experts
