Question about Bell Sports Scout Jogger
Front wheel veering right (hard right)
Our stroller keeps veering to the right, so when I jog with it I am constantly having to adjust the direction of the front wheel which gets to be rather painful through the neck,etc. How do we fix this and get the wheel to head straight. If it is anything like a car, then it seems like the wheels need to be balanced and/or the alignment checked. How can I do that on my own?
  • ymg_feb Aug 05, 2008
    our stroller veers to the left and it wears a person out trying to keep it straight
    Sergeant:
  • 274 Answers
You can take it to a bike shop.  They can re-align the wheel for you.
Posted on Nov 01, 2007
SOURCE:
Chicco 3WD Tech rear wheel needed
Try jogging stroller its easy to Swiveling front wheel & maneuverability. Locks forward for increased stability when jogging or if the terrain turns tough.
Mar 06, 2013 | Chicco 3WD Tech - Canarie Stroller
Can we jog with baby on a Bugaboo Cameleon?
All depends on the quality of your local sidewalks! Lock the front wheels and tilt back when coming to any irregular surface. The Bugaboo is a versatile stroller but not really the best choice for jogging.
Jul 28, 2011 | Bugaboo Cameleon Jogger
While jogging with my Bob Revolution stroller, it keeps veering to the right (I am locking the front tire as instructed when jogging). How can I get this to stop?
There is a silver knob right next to the red front wheel lock that you turn until it straightens out the alignment.Jason
OC Tykes.com
May 04, 2011 | BOB Trailer Revolution Stroller
InSTEP Jogging Stroller
I would try local bike store or the store that carries that brand of stroller.
Aug 30, 2009 | Schwinn 12" Roadster Tricycle
Safe tech tripple stroller
On my stroller there is a little plastic piece just above the front wheels.  If you push it to the left it will lock the wheels.  Push it back to the right to unlock the wheels.  You may have to push a little hard to move it.
Oct 22, 2008 | SafeTech Triple Jogging Stroller
How can I fix the alignment of the wheels of a Bugaboo Cameleon stroller (it veers to the right)?
There are two answers to this problem:
1) The suspension on the front swivel wheels on the Cameleon are adjustable. As the child gets older (and heavier), his/her weight might effect the handling of the stroller. It is recommended that the suspension be adjusted. To do this, move the suspension adjustment forward, as it increases its strength.
2) There has been significant conversation about this problem with the Cameleon's veering if the chassis was purchased before 2007. If so, contact bugaboo via bugaboo.com. Bugaboo will ask you for your serial number, etc. to research whether it is something that is obviously defective.
If you have any further questions, or need help contacting the company, don't hesitate to contact us anytime!
strollerinfo@gmail.com
StrollerInfo
Aug 25, 2008 | Bugaboo Cameleon Jogger
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
My jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
Nov 29, 2007 | Baby Gear
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Bell Sports Scout Jogger Logo
287 people viewed this question
Top Bell Baby Gear Experts
Sheldon Dedek
Jojo
NOEL
NOEL
Are you a Bell Baby Gear Expert? Answer questions, earn points and help others
