Question about Garden
Where is the carb adjustment on echo ppf225 pole pruner
Pruner does not run at high speed engine bogs down when open throttle
4 Suggested Answers
  • 4088 Answers
SOURCE: I HAVE A ECHO POLE SAW PRUNER. 25.4CC ENGINE. IT
Inspect the jet screw (H and L) heads to see if the have slot heads or are 'D' heads which must be adjusted by a service dealer. Make sure to have fresh fuel mix with modern synthetic saw oil in the tank (50:1 ratio). Be sure to shake the container thoroughly each time just before adding fuel to the tank to prevent oil starvation. Inspect the fuel filter and air cleaner for plugging. Also, check the fuel line for decay or other problems. With slot-headed jet screws, turn both CW to stops (lightly), then turn each out CCW 1-1/2 turns. Start the engine and allow to warm up, then pull the throttle full on and turn H needle CW until the engine starts to speed up, but still 4-stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW so that the engine idles fairly well, but will still 'follow the throttle'. If the chain is trying to turn at idle, turn the idle speed adjustment screw CCW until the chain stops trying to move. Hope this helps!
Posted on Oct 23, 2010
kel1guy2002
  • 3740 Answers
SOURCE: new echo hc155 hedge trimmer
Hi and welcome to FixYa, I am Kelly
The high speed needle is inside the carb under the primer bulb diaphragm plates.
See the diagram below item 11:
(Center) As a tech I hate this carb because of the time required to dial it in!
http://www.rcpw.com/lookup/#/Echo_%2f%2f_Shindaiwa/HC-155__S%2f%2fN%3a_S68011001001_-_S68011999999/Carburetor_--_RB-K91
When you make adjustments do not turn the jet more than 1/8 turn per adjustment. If the engine is lean (not enough fuel) CCW adj. Rich (too much fuel) CW adjustment.
Adjusting this carb is tedious. You may have to make more than one adjustment. My experience is.... because you have to disassemble part of the carb to make an adjustment... if you end up making more than 3 adjustments you may need another diaphragm. Just be real careful with gaskets and you should be ok.
Thanks for choosing FixYa,
Kelly
Posted on Apr 30, 2011
  • 4 Answers
SOURCE: The ******** the Fiskars Power-Stroke
Hi, you need to clean the blades and dry them and spray some WD-40 on any thing metal spring, blades, nuts, bolts. They get a build up of tree sap from cutting, regular cleaning and coating them with oil will prolong the life of any metal tools, also when you clean them make sure they are closing all the way without gaps. You may need to adjust the blades by adjusting the screws, take your time and adjust slowly so you turn in the right direction continually checking the gap.
Posted on Aug 05, 2011
Wont start, getting spark. when plug is diped in fuel it turns over. New plug.
Adjustment needed on the carburetor.
Look for the H and the L needles on the carb. Take off any plastic limiter cover, they're there for epa reasons only...
Go on you tube. Type in " how to adjust a 2 cycle carburetor" and you should find multiple videos...
Easy bud... go get it
Oct 19, 2015 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Poulan Pro Pruner cuts off when trigger is pulled past halfway; is this car orator issues?
Most likely carb adjustment. Try enrichment adjustment about 1/8 turn at a time, remembering where is was in case you need to go back.
Oct 01, 2014 | Poulan Pro Gas Pole Pruner Trimmer -...
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Echo ppf-210 power pruner will not stay running? I have changed the plug, rebuilt the whole carb, new gas, etc. Still will not stay running? It will idle a small bit and as I pull the throttle I get no...
check the fuel filter to see if its dirty or not under fuel . also you will have to re-tune the carb . or check for compression in the engine it should be at 120 or above you may also want to change the plug
Sep 26, 2013 | Echo POWER PRUNER
Stihl ht70 will only run with the choke full on. New carb no help.
also make sure to clean out the spark arrester. it can cause back pressure and damage gaskets. also stops power..
Nov 17, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Stihl HT 75 pole saw throttle induces stop
If it dies when you hit the throttle, put a kit in the carb and clean it.
Oct 16, 2012 | Stihl Chainsaw Pole Pruner Ball Bearing Ht...
Instruction manual for pole pruner attachment
Do not use as a coaster.
Do not use to stabilize a wobbly table.
Your pole pruner is not edible.
Do not taunt your pole pruner.
Your pole pruner is not a parachute.
Do not feed your pole pruner after midnight.
Do not use pole pruner to commit armed robbery.
Do not name your pole pruner Carl.
Do not marry your pole pruner.
Do not turn your back on your pole pruner.
Jul 25, 2011 | Flamebrain Technologies WatchMe
I HAVE A ECHO POLE SAW PRUNER. 25.4CC ENGINE. IT STARTS AND RUNS, BUT IT MUST BE CHOKED ABOUT 1/2 WAY. OR IT WILL STALL, IT HAS NO POWER, IT WAS LIKE THIS WHEN NEW. PURCHASED IN 07. TRY TO USE IT EVERY...
Oct 23, 2010 | Echo Garden
Engine will not run when chock is not on
Hi
Try this link to find out where the carb adjusment screws are http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=401c0624-691d-43f6-9249-845e18527269&cat=3&TF=epcFrame&assem=452&highlightNode=No&selAssem=4447&mdDescrip=PP258TP Pole Pruner.
best regards savumihai71
Dec 17, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
