Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Heat won't come on, but AC will for the thermostat digital hunter 44860
  • darrell294 Jan 06, 2009
    air cond. will work but heat will not on my trane heat pump.
  • l krantz Jan 12, 2009
    using trane. heat won't come on. ac will. help
Look at your igniter on the furnace.
Posted on Jan 05, 2009
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Unable to unlock for ac
use the code 777 this will get you in then you can put your own code in or just use the 777 code.
Jun 09, 2014 | Hunter 44860 H Univ. Touchscreen...
Hunter 44860 Thermostat - continually resets clock to 1am
My Hunter 44860 is doing this also. It started on Nov. 1, 2009. It also displays the day of the week as "SUNDAYAY" when it hangs. I believe this is a firmware problem with older stock. Unfortunately I bought it from Lowes this fall and lost the receipt. I am going to try to return it to Hunter Fan Co for an exchange.
Nov 09, 2009 | Heating & Cooling
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Hunter 44860 says heat is running
Does the indoor blower come on when you switch the unit to "Fan/ Run"? If the indoor fan comes on, this verifies that you have both low voltage and high voltage to the unit. If not, you may have one or both voltages giving you a problem. Try this and let's see if we can get it going. This is step one in checking it out.
Good luck and hope this helps
Mar 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
454 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
