Question about Homelite Garden
Homelite 2500 psi 2.3 GPM Gas Pressure washer will not stay on? Oil is good and ran will not let me reduce the choke.
  • 234 Answers
SOURCE: the washer will run about 2 min. then die. i have
It is possible that the oil pressure switch is not functioning properly or you have a lighter oil in the machine than is recommended.
Post a comment if you need more assistance.
Posted on Apr 27, 2009
  • 5 Answers
SOURCE: My TroyBilt Pressure Washer 2500 PSI 2.3 max gpm
if you follow the chemical hose back to the pump it will be attached to a barbed nipple, behind the nipple there should be an o-ring, spring and a ball.
A lot of the time if you are using the proper nozzle in the low pressure setting and still cannot create suction the ball will be stuck to the o-ring. You can just free this up and put a little white grease on the o-ring.
Troy
Posted on Jul 08, 2009
SOURCE: I have a Karcher 2,600 PSI 2.3 GPM Gas Pressure
Hi I have a similar pressure washer from Kartcher and the same scenario as yours I have owned it for about 2 years and noticed that it was getting harder and harder to start with each time I use it which is months. If your pw has a honda engine on it the likely culprit may be the carbuerator. The main and pilot jets may get clogged up with gunk from dired up gasoline. To see if you have a fuel problem spray a shot of starter fluid into the carberator with the choke open, then close it and try to start. If it runs for about a second and dies, then the carbuerator is at fault and you are not getting fuel into your motor and all you're doing is working out your arm.
Posted on Jul 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
My pressure washer just stopped while working, why?
Check your oil level. This machine has a "low oil shutoff" safety mechanism. If the oil is low it shuts down.
Jun 08, 2014 | Ridgid Pressure Washer. 3,300 psi 3 GPM...
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
Won't Stay On
If it's brand new, the first thing I'd check is the oil level in the Honda motor. Most pressure washers are tested then the oil is drained out for shipment. Honda motors have an oil sensor in them that will shut the motor off if the oil level is low. When the motor is off, all the oil is in the bottom of the crankcase and the sensor 'thinks' all's OK. When you start it up and the oil is getting splashed around it will get low enough for the sensor to shut the motor down. Also make sure the gas is turned on at the carburator.
Sep 04, 2012 | Homelite Pressure Washer. Honda 2700 psi...
Where is the drain plug for engine oil on Work Force Pressure washer WF 80710
i cant find one so i sucked as much out from the dipstick/fill plug and replaced with new
Jun 14, 2012 | Homelite Workforce 2500 PSI 23 GPM Axial...
Garden Logo
52 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
