In need of assistance with an RCA Model#G35302WK, Chassis#CTC169BF, 35" TV. Require RCA Part# for Resistor R1V (1.8 ohm, 10%, 15 watt). Service information inside cabinet only identifies part with Componant ID# ( R1V ) ..... unfortunatelly Part# not listed. Service information indicates/states "refer to service data for more detailed information". The parts provider that i have located list replacement parts using RCA's part#'s, nothing else........ so i'm at a standstill! Can you assist with RCA's Part# for this componant.......... or provide Service Data Manual for this Model ? Thank You for your assistance. Harlow Melton
    Problem Solver:
  • 11 Answers
RCA part #200444
Posted on Jan 04, 2009
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
I have Hitachi 57F500A, the resistor RK62 is out the replacement with the kit are different what I need to know it the right answerer for the RK62 what is the ohm 2.2 or 1.8 I see two different people have...
RK62 is a 2.7 ohm 1 watt resistor for stock IC replacement. If you use the STK394-160 ICs then the resistor ratings will be different. Your Chassis is the DP23
Feb 14, 2011 | Hitachi 57F500 57" Rear Projection...
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
Need r 114 u resistor
I have the schematics for this TV but the only resistor I see is label as R4114 and its value is 10K ohms, 5% 3 watts.
I could send you the schematics.
Let me know if you required further assistance.
Apr 07, 2010 | RCA F19207BC TV
Wattage
1 watt,Service Manual I have says RK42 3.3ohms RK46 1.8ohms RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
Dec 30, 2009 | Hitachi 50FX20B 50" Rear Projection...
RCA L42WD22
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
Apr 03, 2009 | RCA 20F511T TV
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
Part numbers
wiil get back to you.
Mar 16, 2008 | RCA 32F531T 32" TV
No Pic...power light only, on plug in
R414 is a 13K ohm 1/6 watt resistor.
Sep 27, 2007 | RCA 14F512T 14" TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
