Question about Samsung Washing Machines
Samsung WF448AAP/XAA 04 Front Load Washer....Wire that holds rubber gasket in place to seal around front door has fallen out...how do I put it back in properly?
When I finished a load yesterday, I opened the door and the wire that holds the rubber gasket around the front door was hanging out. I also noticed a little water had escaped from the washer, which I am sure was the result of the wire coming out of place....not sealed properly. I'm sure its a fairly simple fix, but knowing where exactly to place it is the problem!! Thanks for your help
catriver
  • 878 Answers
SOURCE: front load washer
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Posted on Aug 10, 2006
jsrock516
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
futureloginn
  • 734 Answers
SOURCE: leaking door due to the wire ring that holds rubber seal
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
woobie dog
  • 1273 Answers
SOURCE: Wire ring that holds rubber seal on next 100 washer has come off
Loosen the screw (mine has one) and slip it over the hump and into the groove. Don't overtighten. IF all you have is a spring, slip the top of the ring over and into the groove and slowly work the remainder over and down by holding the spring part apart until you get the ring clamp as far over as possible. If you have some silicone spray, this will help.
Regards, --W/D--
Posted on Jul 24, 2009
Why has drum fallen out of place?
You have a bearing problem and best if you call a service company on this one!
Aug 09, 2015 | Samsung WF448AAP Front Load Washer
The wire has come out of the seal in my whirlpool washing machine.. how do i put it back?
that wire is a steel clamp to hold the rubber onto the tub an front . you'll have to remove the front to put it back on . a real project.
see this video at time 2:04 for that wire
https://www.youtube.com/watch?v=ehwsMILlaTY
May 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
Wire that holds the rubber gasket came off
can usually take to people if you are not familiar.the spring does down towrds the bottom of the boot in the middle of the boot start with the ring at the top and go down both sides the have someone hold it in place about the 10 and 2 o clock positions while you use your hands or small screw driver and finish putting the ring in place
Jun 10, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Duet ghw9100lwi inside gasket on tube is wrinkled - what could have happened -is that what they call gasket, tube in the scamatics? and is that what they are referring to as a bellows gasket on this site?
If you are referring to the wide gray rubber bellows gasket that goes between the outer body of the washer and seals to the outside of the drum (fits to the washer's window when door is closed), it can get wrinkled or skewed if something gets caught between it and the door and a load is run. Mine did this years ago (and in fact ripped slightly) when the corner of a pillow got trapped, then a cycle was run
You can fix this fairly simply yourself, especially if the gasket is intact. Look around the outer edge of the machine (where the gasket intersects the front panel) and you'll notice a wire clamp that holds the gasket in place in a trough on the front panel. Follow it around until you find the end of the clamp. As I recall, there is simply a wire oval holding the ends of the wire clamp. Use a vice grips or needle nose plier to compress the ends of the clamp, then remove the fastener and the clamp itself. Readjust the gasket so it is straight (there is a small hose coming through at the top of the gasket for orientation) and reverse the steps to reassemble the clamp.
Hope this helps! Sorry if it seems a little vague, but this is all from memory
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
