Question about Nikon COOLPIX L3 Digital Camera
Lens Error turn on the camera the lens comes out & then goes right back in saying lens error
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
My EX-S5 says lense error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
My camera says lens error when i turn it on
Jun 09, 2009 | Canon PowerShot A560 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
TURN ON CAMERA THE LENS GOES IN AND OUT JUST A LITTLE THEN SAYS LENS ERROR
May 21, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error
Did you try replacing batteries.
will it turn on long enough to restore it?
if this is a new camera send it back it could be a software issue or mechanical breakage.
Also get a can of air and blow the lens off to ensure no debris is holding it back.
YOU CAN AT YOUR OWN RISK try to help the lens come out a bit by gently pulling it in case of a weak motor this can help but eventually it won't work anymore.i've heard tapping it where the usb cover is helps. try to gently tap it on a table as it is powering up.
read this it might be related:
http://www.e18error.com/repair.html
one of the things here might work to fix several problems other than error 18
Apr 23, 2009 | Canon Powershot SX110 IS Digital Camera...
Lens error!!!!
when i turn on my camera the lens comes out ,then goes back in saying theres a lens error.it tells me to restart my camera but im not sure how too. is it just turning it back on ,or is there a reset button?
Jul 03, 2008 | Canon PowerShot S5 IS Digital Camera
Lens error 25 and 15
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
112 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
