Question about GE 24 in. GSD4320Z Built-in Dishwasher
Dishwasher will not drain
GE profile GSD4320 . I have check drain hose, not pluged. I was able to get it to drain by running in test mode and bypassing the fill up sections and just letting the pump run. No problem ubtil yestarday now that won't even work. I'm handy and bit short on cash and would like to fix myself if possable. Is there a timer in it that may be not working or do you think I need a nes pump??? Thanks
  • 3 more comments
  • Tina Coley
    Tina Coley Jun 05, 2007
    Thank you, I will take it apart and check this out.
  • Tina Coley
    Tina Coley Jun 18, 2007
    Thank you for the advice, but my dishwasher does drain when I go thru the product test feature. It just will not drain during it's regular cycle. When I put it in test mode the fourth test : water valve and main pump for 16 seconds...works fine. But the #11 test ..main pump and heater for 60 seconds...it does not drain.
    Is there a timer possibly that may be malfunctioning???
    Model number GSD4320z00bb FT806495B
    This is one of the GE Profile machines that has been effected by the additive area leaking. I have a rebate form for $300 towards another machine, but another one costs more then double this amount. Could this have happened by the wires in there getting wet from the additive???
    Thnaks
    tlchi
  • Anonymous Jan 23, 2008
    I have a portable Kenmore QuietGuard 1 dishwasher that is less than 2 years old. Sometimes it will drain completely, most times it will not. I took the spinner thing off on the bottom and noticed that a little part that is sort of like an O ring is broken. This part fits inside the arm and I think it must be something that helps or allows the sprayer arm to spin. Could this possibly cause it not to drain? The pump sounds like it is trying to work when I cancel the load to drain, so I don't think it is a pump problem. The little ring is about 2 inches in diameter and is about 1//8 inch tall.  I hope this makes sense. Thanks....
  • allok65 May 28, 2008
  • gkorenek Apr 02, 2009
    I also have a GE GSD4320Y73 Profile dishwasher. It is approx. 11 years old.
    My case is similiar, except the dishwasher will not drain on the very last cycle only. So I wash a load of plates, and then when the wash is done I spin the timer knob to "start" because the first operation of the wash is to drain the tub. Since the drain operation only fails at the last cycle, does this point to a timer problem? If so, how hard is it to replace the timer? I am reasonably handy. Thanks!
    President:
  • 878 Answers
Tichi, without a complete model number and using a model close to the one posted, there is a couple of things you want to check. It appears that you have a drain solenoid assy. that sits on the left side of the motor assy. If this selonoid overheats or fails, you will get a no drain situation. It is not hard to install a new one. I have found on these models that a defective timer will continue to send voltage to these selonoids and burn them up. Result, no drain. There is also a piston and nut assy. that sits under the filter screen in the back of the tub. You can get this from the inside. If this piston nut assy. does not seat as designed, you will have water in tub after the drain. From your post it sounds as if the drain selonoid is bad. I will attach a couple of pictures of these parts.
Posted on Jun 04, 2007
  • Ron Marek
    Ron Marek Jun 04, 2007
    Piston nut assy.
GE DISHWASHER PDW7300N10WW DISPLAY SHOWS RANDOM CODES AND BEEPS CONSTANTLY.
old post. but I am posting here, to help , searchers.
this model has a full computer behind that panel
with service modes and factory test modes.
and a service manual..
try cycling power, (pull main power plug for 5min.)
make sure the drain line is not blocked. (i use a 5 gallon bucket to test my washer drain hose. 2 person, one to hold the hose firmly in his hands , aimed at buck. (the resest button kills all actions)
the beeps are error warnings, covered in the manuals.
there are many beep modes.
even door left open, does that, soap dispenser (option) empty.
the first tests on a PDW, washers, is the rinse, only mode.
when started, it first pumps the sump dry. (old water ejected)
if the pump do dose not start, but humms.. the drain is blocked.
then does a full rinse run. if not make sure the water valves are on.
these models have a Service mode, and a factory test mode
both are covered in the service manual, and allows the manual
testing of each mode and device in the washer.
The turbity sensor can get limed up , so run 1/2 cup of vinegar
in rinse mode. once running.
GE does not offer the serv. manual to DIY, but google does find them, if you search long and hard. "for sure"
is is a generic help page, but do not down load his helper browser bad (jeckle and hyde site) the HTML pages are safe.
http://www.appliancerepair.net/ge-dishwasher-repair.html
Aug 23, 2013 | GE Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
GE profile dishwasher won't drain. It has happened twice now
Hi
If you can hear a humming noise, then that is the problem due to pump.The pump gets energized but not rotating probably due to something stuck in the impeller. Check for that impeller unit and try to replace it.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Thank you !!
Jun 24, 2010 | GE Profile PDW8400J Built-in Dishwasher
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
GE profile dishwasher (2004) will not drain properly. Is the drain clogged? If so, how do I open and clean it?
check the hose first alot of times the hose canbe clogged . disconnect the hose hit the drain on the machine and normally the clog will be seen. if that doesnt work then its the drain pump thats clogged.
Mar 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile 7880 will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile PDW8280J10SS: Water won't drain. I
Can you get the water to drain at all in any cycle? If you can, then its possibly the control module .
If you can't get it to drain in other cycles or when you cancel the cycle, then its a possible clog in the drain outlet hose, drain solenoid, or screens.
Here is a good detailed link to check out that explains about it:
http://www.applianceaid.com/gedishdrain.html
Heres another link about general dishwasher draining issues:
http://www.applianceaid.com/drain_wash.html#drain
Apr 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Open Questions:
See all GE 24 in. GSD4320Z Built-in Dishwasher Questions
GE 24 in. GSD4320Z Built-in Dishwasher Logo
1,119 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
