Question about Frigidaire GLTF2940ES Front Load Washer
Frigdaire washer can you please walk me through it
  • tonyanjanes1 Jan 03, 2009
    ok thats all done, need to start cleaning out pockets, my 7 yr old just got a penny bank full, now what do i do after i clean it and put it back together.
  • tonyanjanes1 Jan 04, 2009
    ok did that, and put it back together and nothing was blocking it. thank you so much,
  • 640 Answers
Ok no probelm..you have a front loader ,,first un plug unit,,now at your feet theres a toe panel,,3 screws remove them and the panel will slide down..now off to the cener left the thing with the little fan on front and the 2 black hose coming out,,1 hose lead out the unit to your drain and the other hose comes down from your tub...take that 1 of from your tub to pump but take it of from the pump ,,if its water in the unit ,,dip much as you can out and then put towel on the floor..now see whats jamming pump..im here for any questions,,,reverse to put together..onthejob
Posted on Jan 03, 2009
  • onthethejob1
    onthethejob1 Jan 04, 2009
    no dont put it back yet take a small screw driver and make sure that impeller rotates..unplug and use you finger slowly..we have to make sure nothings blocking that line,,,take a paper towel ot put over drain hose and blow through it ..go slow while its open dont want you to close before we check...im here
  • onthethejob1
    is it working...???
Frigdaire top loading washer # FFTW1001PW gets stuck in wash cycle. It agitates and drains but stays in wash mode. Is there a way to fix this?
possible problem program board not progressing
call in a technician for a proper diagnosis and quote
Sep 03, 2016 | Washing Machines
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
How do I level my frigdaire gallery front load washer
Thank you for your inquiry, friend!
In order to properly balance your Frigidaire washer you would need to seek the help of a professional. Regrettably, this is not a simple DIY job and I would highly recommend reaching out to an expert technician to ensure the repair is correct to prevent future issues. I hope this information helps to some degree. -Matt
Oct 11, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigdaire heavy duty washer 13 cycles 2 speed motor. Washer no longer detects the water level. if you have it on small just continues to fill with water and never stops.. Washer flooded gargage. Any...
This can be due to failure of the pressure sensor within the washer which should output to the processor to cut off the inlet valve when the set water level has reached.
You can test this out by blowing into the tubing and testing the continuity of the switch to confirm if the diaphragm is intact.
click this link: Replacing sensor
Jul 04, 2012 | Frigidaire Washing Machines
My frigdaire stacker combo dryer wont spin? The washer works fine. It seems very tight, why could that be?
Possible that the bearings are worn out and so the drum is not free as the spindle is stuck up and so does not move fully in the spin cycle.
check this link for tips to check and replace the bearings: Washer bearings
Jul 02, 2012 | Frigidaire Washing Machines
Frigdaire front loader leaves black marks on clothes
the bearing oil seal has probably broken down, black greasy marks are a giveaway.
Oct 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Mine just started - same Model ATF7000ES!
I have a Frigdaire Gallery model front loader. It is leaking underneath the machine. It is 7years old. Does this model haave a history of rusting out? Roy Ingham
Jul 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Apr 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
