Question about General Electric 100Amp 3-pole circuit breaker
Hello: I have an old electrical box with the old style Zinsco beakers. For some reason, the left side of the main 200 amp breaker continues to go out. only one side. the breaker arks right where I screw it in from the source. The breaker does not feel hot but the lights inside my house continues to flicker. Can you help. Rob
  • 3 Answers
You should repair your zinsco panel... go to my website at zinscoelectrical.info , and get a new buss bar and breakers.... Good luck
Posted on Aug 12, 2011
    President:
  • 2,976 Answers
The screw is loose. It is always HOT (has electricity going to it) so be careful. If you feel confident, cover a screwdriver with a few layers of electrical tape and tighten it. Depending on how long it has been arcing, the breaker will need to be replaced. Since the incoming wire will have power to it, have a licensed electrician do the job. He will possibly remove the meter head to cut the power while he does the work.
Posted on Jan 03, 2009
How to find zinsco main breakers?
HomeDepot.com carries Connecticut Electric breakers. They can supply breakers for outdated electrical equipment, including Zinsco (Sylvania), Challenger, ITE push-a-matic, Wadsworth, etc. Prices are high though, it would probably be better to purchase and install a new panel.
Aug 26, 2014 | Electrical Supplies
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
How do you remove old breaker for replacement.
If you have a main breaker turn it off. If your installation does not have a main breaker, I would not attempt to remove breaker if you do not have the experience.. With electric off, remove cover. Locate the breaker you wish to remove. Grasp breaker and pull the center out and to the side. It will disconnect from the buss bar and when it is out far enough the tab on mounting bracket will disengage. Now the question is why do you want to replace it. If yours is the larger style Challenger breaker (formerly Zinsco) and the breaker is bad, you may have damage to the buss bar where the breaker was removed. If this is the case then this position is not usable any more, and if needed the panel will have to be replaced. If it is the style in the picture here with your question, then you may be ok. If you're trying to remove a 1" breaker and install twins or 1/2 size breakers to get more circuit spaces, be aware these only fit in spaces designed for them. You can tell by looking at the legend on the panel cover. The spaces that will take these will have a dotted line indicating it can be divided in two.
Oct 17, 2010 | Challenger 30 Amp 2 Pole A230 A Circuit...
I have a 200 amp service panel i have a 100amp
Theres a few different ways to set up the secondary panel. The most efficient way, in my opinion, would be to set it up as a subsidiary. This is a really great way to allow power to be shut off for sections of a house instead of killing everything. This requires wiring it to the main panel on a breaker which will serve as the main for the 100amp subsidiary. Obviously this will require that a comparable breaker be installed in the main 200 amp panel to support the new subsidiary 100 amp panel.
Here's where it gets tricky and you really should either consult or contract a licensed technician. Because the amperage rating does not dictate the amount of power that is supplied to your house on the primary line you are essentially using the new box as a splitter. The danger in this is that just like any common electrical outlet, the more stuff you plug into it the more likely you are to overload the circuit and risk catastrophic failure, like a house burning to the ground or worse.
Knowing that your panel is side by side, you should be fine with #2 AWG, I would confirm electrical code before installing and ensure that grounds are diverted to the main panel to avoid the risk of running live current through the otherwise 'safe' ground.
If you are installing the panel to increase the amount of breakers it is probably safe to assume that there has been some previous work done that fills up the main panel. I would strongly encourage you to talk to an electrician about your needs and the changes in your house that require the additional breaker slots. There is a certain amount of artistry involved in 'designing' the house and you could probably accomplish the same end result with one panel and a more efficient wiring plan.
Mar 08, 2010 | Your One Source Homeline Load Center, 200...
Is there more than one style of AFCI breaker that connects to the main box? I have a 150 amp service box but the connection at the bottom is backwards.
yes there are a few different types of breaker designs ==either bring old one with u to match up or ask what type urs takes[need make of breaker panel] to an electrical supply,home store,or hardware store
Jan 26, 2010 | Eaton 20A ARC FAULT BREAKER
I live in a mobile home with a westinghouse DP 200 amp main breaker. it trips alot when i run the stove and the dryer along with other items.
You need to run a new circuit to the stove before your electrical wires catch on fire. that is a hazard you have taking a big chance if left alone. Your old wires and breaker is not heavy enough to run both so a complete rewiring job will be in order if not reaired very soon I would say from past experiences I've encountered
Jan 18, 2010 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
I need to add an electric panel box!
Before you contemplate doing this I would check to see if the 200 amp wiring to your home can accommodate 300 amps. If not, I would not touch it. If it can then you can do it ever so carefully to make sure you do not light yourself up! I would kill your main 200 amp breaker and then tap into each existing branch a tap that will take at least 50 amps for each of the two legs on your new 100 amp breaker box. Good luck
Sep 22, 2017 | 2005 Peugeot 405
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
General Electric 100Amp 3-pole circuit breaker Logo
196 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
