Question about Refrigerators
How to replace a Sub Zero 361rfd solenoid valve?
5 Suggested Answers
kdgrayson
  • 195 Answers
SOURCE: MY MODEL 3211RFD sub zero ice maker quit. Got
timer
Posted on Aug 23, 2009
  • 1218 Answers
SOURCE: I have a 20 year old sub zero side by side model
Good day,
The defrost control on that model could well have failed. If it failed in the defrost mode, then the compressor and condenser fan motor would not run.
The timer is easy enough to remove. Take it to any appliance parts house. A good counter man if you explain the machine is not running could check the contacts that run the compressor.
If it's noisy I would replace it anyway.
If they can't cross the timer, just ask for a replacement with a timing sequence of 8 hours-30 minutes. That means it will run the machine for 8 hours, then shut it off, and defrost it for 30 minutes.
The other possibility is the cold control (thermostat which is located in the fresh food compartment.
That cold control is expensive and labor intensive to replace.
Buy it only if necessary.
However, both items are popular replacement items on your machine.
Posted on Dec 21, 2009
Testimonial: "Thanks for the advice. I tested the defrost control and it is working. I believe it is the thermostat!"
  • 71 Answers
SOURCE: Describe how to replace a solenoid valve on a subzero 532
easy.. disconect power . important. remove the kick plate. the water valve is locate in the left side. its a blue color. inside a bracket or attached whit 2 screws ( depend on the serial break) remove the water valve from bracket. disconect the plug and the and the line and thats all.............................................. NOTE. MAKE SURE TURN THR WATER SUPLY MOST LIKELY IS THE COOPER LINE . CLOSE FROM THE WATER METER OUSIDE YOUR HOUSE OR CLOSE TO THE WATER VALVE....... DO NOT TRY TO REMOVE THE FRIDGE.............. good luck... LEAVE YOR COMMENT IF IT WAS GOOD FOR YOU... THANKS
Posted on Apr 02, 2010
  • 184 Answers
SOURCE: I have a sub zero
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Posted on Aug 18, 2011
Does the sub zero model 361 rfd refrigerator have a separate thermostat control for the freezer ?
No, the 361RFD does not have a separate control for the freezer as this unit has a single compressor. The control is located behind the back panel in the refrigerator compartment and the part number is 4201470.
Jul 21, 2012 | Sub-Zero Refrigerators
The ice maker won't stop dripping.
The problem is going to be the water inlet valve isnt fully closing and seeping water through it all the time. To fix it the water inlet valve would need to be replaced,typically on all Sub-Zero brand refrig's the valve will be up by the compressor in the area above the ref. behind the top grill.
Also while up there replacing the water inlet valve be sure to clean all the dust from the condenser coil as well as replacing the water valve.
GENE
Sep 06, 2011 | Sub-Zero Refrigerators
Subzero user manual model 361RFD
Dear Keikozone,
We may be able to offer some assistance. Sub-Zero does offer an electronic PDF version of our older model 361RFD unit. Please call us directly and we can have the manual sent to you. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 05, 2011 | Refrigerators
I have a 20 year old sub zero side by side model 361RFD. The compressor and condenser fan aren't running. The defrost controller appears to be making a noise and is warm.
Good day,
Dec 20, 2009 | Sub-Zero 690 Side by Side Refrigerator
Oct 06, 2009 | Sub-Zero 632 / S
COMPRESSOR RUNS, AND IS HOT TO TOUCH, FREEZER WONT STAY COLD IF O
either your evaporator and condenser coils are very dirty or your low on r22 freon
Jul 31, 2009 | Freezers
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
