Question about Kenwood KDC-MP332 CD Player
Assistance with diagnosing HU problem
Hi. I have a kenwood kdc-9015 car stereo.It just stopped working. It flips on and nothing comes on the display. I checked the fuse behind the HU and it is fine. I unhooked all the wires to reset, and the same results. I have an eq and then 2 amps running. All those turn on through the kenwood. The eq and amps power on and off, so I disconnected them completely for now. Any ideas?
SOURCE:
robotek
  • 1512 Answers
SOURCE: security problem
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Posted on Dec 14, 2007
Duncan
  • 219 Answers
SOURCE: kenwood kdc-7007
Your owners manual or the web site for Kenwood or try www.radio-code.com to get the factory code and the proceedure for inputting it into you radio. Good luck.
Posted on Apr 23, 2008
  • 29 Answers
SOURCE: kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Posted on Sep 07, 2008
shagone
  • 34 Answers
SOURCE: Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: Kenwood KDC-MP825 car stereo problem
My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
This appeared to have solved the problem:
Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
Posted on Dec 08, 2008
My kenwood kdc 136 works normal for ten minutes then stops and displays ;ocer
I had an issue like this took me months to fix it. I finally just put in a higher grade fuse in. I think it had a 10 and i put in a 15 worked after that but mine was not wired to the battery. I would say check your fuses and wires.
Apr 20, 2014 | Kenwood KDC-138 FM / AM Receiver
I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Jun 24, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Display disappeared on kdc 8021
If you mean that the rotating cover has flipped back round covering up the control panel turn on the ignition and push the top left of the panel. this should make the cover flip back around and make the interface available.
Jan 12, 2009 | Kenwood KDC-8021 CD Player
Kenwood KDC-MP832U display not working
I had this problem! It was the Cars Battery. Kenwoods unit's fade or go completely blank when there is little power to power the stereo. Try charging your battery or grabing a new one from a scrappy! I was all over the net looking for help but finally sorted it!
P.S. My younger brother had to do the exact thing and it worked for him as well!!!
Jul 20, 2008 | Kenwood 1080VR Receiver
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
KDC-MP919 No display
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
My head unit is awkward.
Check the wire braid going out to the faceplate. Although this is a fancy feature. it is very problematic. But usually it looks like a flat plastic strip with brown stipes on it. Sony calls it a flexible circuit board. after so many flips wires break the buttons stop working and when the face gets just is the right place it stops turning. but is repairable if you can order the braid from Kenwood about a skill level five to put in.
Sep 07, 2006 | Kenwood KDC-519 CD Player
Kenwood KDC-MP332 CD Player Logo
48 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
