Question about Xerox WorkCentre XE88 Laser Printer
E7-03 error code on work center xe88 xerox
Keep getting error on Xerox xe88 work center. No ones sells them in our area. Need help please
  • Anonymous Mar 18, 2014
    xerox work center 7242 code 041-312
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Hello. We have 2 Pcs of Xerox Copier
Try removing the fuser and re installing it.
If that doesnt work then the fuser is bad.
Nov 10, 2010 | Xerox DocuColor 3535 Copier
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 30, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Xerox WorkCentre XE88 copier
Black line usually caused by cleaning blade failure or drum damage
If the fault only occurs when using document feeder and not off the glass, clean the scanner glass (the narrow strip at the side of main glass if fitted)
Drum /cleaning blades are usually contained in the "throw-away" cartridge It would be nice if you could find someone with same machine you could try a swap to prove it
Nov 15, 2007 | Xerox 8825 Copier
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Xerox WorkCentre XE88 Laser Printer Logo
163 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
