Question about Canon Cameras
I have a cannon E330 8mm video camcorder 1993. I can't get i to keep a cassette in it. it just keeps opening back up again.
This is not a digital camcorder.
cpt100
  • 154 Answers
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Posted on Mar 17, 2007
  • 158 Answers
SOURCE: DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Posted on Aug 13, 2007
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
Pyrhyc
  • 2028 Answers
SOURCE: I have an old Video
Your eject problem will be one of three things. 1- the gears for the eject mechanism have shifted and not making contact with each other. You can fix this by realigning the gears. 2- The gears are stripped and need replaced. 3- there is a small plastic pin that releases the cassette bay. check to see if this pin is broken. If so, then you will need to replace the pin or the gear the pin is attached to. With this being an older model, parts will be extremely hard to find. Let's hope that the gears are just misaligned.
Posted on Aug 05, 2008
charcois
  • 763 Answers
SOURCE: Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Posted on Oct 03, 2008
The screen keeps saying reinsert cassette and I reinsert the cassette and it says it again. I tried a new cassette and same thing.
Take it to the repair service. I am really suspect who's still use a reinsert cassette so today,Refer to old Sony DCR-TRV285E Accessory ,and I didn't know a Sony DCR-TRV285E Digital-8 Digital Camcorder model ,please say clear and correct !
Dec 16, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Eo3 safe mode
Problem with reel, could be your cassette causes the problem.In case your cassette stuck, eject the cassette by applying power on it and keep cassette door open for 5 sec or more until cassette ejected, then use other cassette. Otherwise have it check by the expert. Good Luck
Mar 04, 2010 | JVC 580136 Camcorder
Camcorder continues to show"REMOVE CASSETTE" notice
You are not alone. This is a known service problem for this series of cameras. Cannon has a service notice on its website. Look here:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=227&modelid=9037
Sep 23, 2009 | Canon Elura 40MC Mini DV Digital Camcorder
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Panasonic dv camcorder keep havin
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time leaving the cassette inside and the battery attached.
Solution:
1.
Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2.
Push on the right place (marked "push") to close and then close the
cassette housing.
3.
Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder for long period without being operated, and store the camcorder in a dust/humidity protected place.
Hope this can help.
Abdullah
Jul 14, 2008 | Panasonic Video Cameras
Mini DV Cassette won't come out. Cassette case moves up and down but doesn't open.The display keep on saying Cassette is ejecting.I don't use it as often.
I AM HAVING THE SAME PROBLEM. HAVE NOT USED THE CAMCORDER FOR A YEAR AND A HALF. IT MECHANISM MOVES IN AND OUT BUT WILL NOT OPEN UP TO PUT A TAPE IN. VERY FRUSTRATING.
Feb 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Push the reset button
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Hope this can help.
Jan 10, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Cassette will not load!
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100.
Jun 22, 2007 | Canon ZR100 Mini DV Digital Camcorder
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Cassette will not stay in
this is a serious mechanicle problem, you may have to take it to the service center, or else blind tries may spoil the equipment.
Mar 03, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Cameras Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
