Question about Kenwood KM300 Chef Stand Mixer
Kenwood Chef A901 - grease coming out of hole in gearbox
I've just been given an old Kenwood Chef A901 mixer.
Under a small cover on the top of the machine is a hole about 1cm in diameter with a screw thread. A lot of grease is coming out of this hole.
I'd like to block it up.
Any info about what the hole is for, and how to stop it leaking grease would be welcome.
How can I service an A901 kenwood mixer, need to get top plate off.
the speed control on my kenwood chef A901 is not working
how do i fix this.
Oct 16, 2012 | Kenwood Chef Major A701 A901 Cm170 Km201...
Tip
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
on Jan 05, 2010 | Food Mixers
Kenwood a901 service manual please
Ring for the customer service number and they will provide you .
Jun 12, 2012 | Kenwood Chef Major A701 Food Mixer
Service manual needed for kenwood chef a901
Could you send me a service manual for an a901 please? Just inherited one from my nan, and serviced it but stupidly cant remember which order the lower bearings go on the motor :/
gileswjones@hotmail.com
Jul 14, 2010 | Kenwood KM800 Major Classic Stand Mixer
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef A901, not working
Found a kit on ebay for 9.99 which fixes the speed cntrol problem on 901 chefs do a search for kenwood motor repair comes with instructions you would need to be ok with a soldering iron
Dec 14, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
Dec 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood will not turn
It is possible that the drive belt has broken. It is located under the housing on top of the mixer but you need to remove 2 screws under the housing then remove the 3 retaining screws on the drive mechanism. The top of the housing will then lift off and reveal the drive belt. Caution this is not a DIY job for non mechanically minded persons and as always make sure the equipment is disconnected from the power supply. If in doubt seek qualified assistance.
Mar 12, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood KM300 Chef Stand Mixer Logo
999 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
