Question about Lexmark X9350 All-In-One InkJet Printer
Printer carrier stall for Lexmark x9350 loose belt for cartridges
The printer cartridge belt has come loose from the reel and is hanging loose. There is a sping coil that is not connected--the error message reads "check inside printer for obstruction, then press check mark". Is there a replacement part for this and how I find it?
  • Anonymous May 14, 2009
    Exactly the same problem. Called Lexmark support - part is not available.
3 Suggested Answers
cracker12
  • 31 Answers
SOURCE: PRINTER CARRIER STALLS
Check printer drive belt for worn out teeth and also ensure that the printer shaft is free of greezeand dirty.
Posted on Jul 13, 2009
thydzik
  • 86 Answers
SOURCE: Lexmark x9350 printer problem
this is the result of a lose belt or dislodged spring, tightening the belt.
There is not much you can do, you can attempt to open the printer up and tighten the belt, however, it would be easier to buy a new printer.
Posted on Jul 21, 2009
X9350 loose belt
This printer has opposite side belt driver gear please adjust this gear
Apr 24, 2013 | Office Equipment & Supplies
Cartridge stall lexmark z705
Please go through the following steps to identify and fix the problem you are experiencing:
  1. Open the printer cover.
  2. Remove the cartridges. Check the cartridge area for any foreign objects or debris blocking the cartridge carrier.
  3. Check behind the cartridge carrier for the encoder strip (transparent strip responsible for the movement of the carrier) and make sure it is seated and not loose in its place.
  4. Close the printer cover.
  5. Unplug / re-plug the printer into the power source to reset it.
  6. When the printer turns on, reinsert one cartridge first. Then close the printer cover.
  7. Check for any errors.
  8. If none, reinsert the other cartridge.
  9. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to identify if it's a faulty cartridge issue.
  10. If cartridges are good and no error appears, try to print a document to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Z715 InkJet Printer
The "on-off" light is flashing steadly... while
The flashing light could either indicate a cartridge problem or the printer carrier has stalled.
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed. To do the hardware test, follow the steps below:
  1. Switch the printer off.
  2. Put one sheet of paper into the paper feeder.
  3. Press and hold the power button and the paper feed button for three seconds until the power light comes on.
  4. Release both buttons. After three seconds, the printer will start to print. You should obtain a page containing a series of horizontal color lines, and a thick black line below these. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not turn off the printer, it will keep on printing this page.
To check if you have a cartridge carrier stall, follow steps below:
  1. First unplug the printer.
  2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
  3. Once the cartridges have been moved across, you can clip them out.
  4. Try to print without the cartridges in the carrier.
  5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Try to print a document to check if printer is working properly now.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sources: - Lights Flashing on the Printer - How to Perform the Hardware Test on the Lexmark X74/X75
Jun 25, 2011 | Lexmark X75 All-In-One InkJet Printer
When i opened my lexmark 1200 printer to replace the ink cartridges, i noticed a long thin strip of plastic was loose. and now the cartridges dont move back and forth smoothly but clunk to either side and...
If the encoder strip has become unseated: 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover. 3 Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer. 4 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back. 5 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 6 Reconnect the power supply and turn the printer back on
If you need some graphical reference, please refer to this article: Printer Cartridge Stalls or Is Blocked .
Apr 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x9350 won't recognize new cartridges
hmmm this s the prb in u r printer settings...u jus give a print test after fixing the new cartridges...then if it works then there no prb in cartridges...or else there s dust in the printing rod...u jus want to giv the printer for service so that they will clean the motor of the printer and u r printer s set for working...cool!!!!
Jul 25, 2009 | Lexmark X9350 All-In-One InkJet Printer
Jul 21, 2009 | Lexmark X9350 All-In-One InkJet Printer
Lexmark x 1270 cartridge stall when about to print the cartridge would move to the left of printer and stall there.is there any way to fix the problem please and Thank you to any one who can help
Please follow the steps given below to install the cartridge:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridge carrier is in the middle, please make sure that the cartridges are snapped firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
Apr 29, 2009 | Office Equipment & Supplies
Blinking lights on Lexmark Z12 printer
Unfortunately, the Lexmark website is set up so I can't provide you with direct links to the workaround for these problems....
Go here: http://support.lexmark.com/perl/support/support.cgi
Do a search on "blinking flashing lights + Z12"
and try to follow the steps outlined in the troubleshooting guides that calls up.
This is the most likely candidate, but there are others that could cause this symptom:
Lights Flashing on the Printer ID: 241
If the power light on the printer is blinking, you may have a carrier stall. To check this:
I hope one of these options will provide you with the solution to your problem. If not, please write back with a report of what you tried and we will try to help you further.
If I have managed to answer your question or solve a problem, please take just a moment to rate this posting....thanks!
  • Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
  • If the power light on the printer is blinking, you may have a carrier stall. To check this:
Mar 28, 2009 | Lexmark JetPrinter Z12 color InkJet
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X9350 All-In-One InkJet Printer Logo
548 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
