Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Menu will not display
On my Magnavox 9P6034C 60 in. rear projection the menus do not show up. This includes the channel display and the volume display. Doesnt matter if i use the remote or controls on the the controls on the tv. Any ideas?
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
Posted on Aug 11, 2007
Very low volume on phillips big screen tv
From the model number it is a older set (model listed here).
Simple things: if using a cable or sat box to it via rear jacks etc volume may be turned down on the box!
A few sets in menu have volume limiter--in main menu audio section
Also and last check to see if with a DVD etc hooked to one of the rear sets of jacks if same problem....rules the set in or out for this problem.
If none of this helps--audio circuit problem and shop repair.
Apr 17, 2012 | Philips Magnavox 9P6034C 60" Rear...
No picture on t.v everything else work
Try pressing the menu button and see if the on screen display works. If it does I would check the solder on the vertical output IC located on the LSB ( deflection Board)
Jun 15, 2011 | Philips Magnavox 9P6034C 60" Rear...
I have a Philips Magnavox 9P6034C 60 in. Rear Projection Television the whit bulb is gone out where do i get another one
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2011 | Philips Magnavox 9P6034C 60" Rear...
Cable problems
Go into your Menu under Tuner, make sure Cable is checked or high lighted, then proceed to Auto Program.
Feb 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Digital Convergence Mode
Jou must hold in the menu button wille putting set on and press the code wile hulding in the menu button on tv.
Feb 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Black screen
check to see if the closed captioning feature is turned on. if it is then turn it off. I see this alot with CC
C-Dog
Feb 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
104 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
