Question about Kenmore Refrigerators
Kenmore model 253.7419240p water pooling under crisper
Kenmore model 253.7419240p water pooling under the crispers and water on the top shelf. is this a frozen or something stopped up.? Thanks
  • 8 more comments
  • Simmone Nov 05, 2012
    Hello there is no ice build up in my freezer at all.
  • Richard Roth
    Richard Roth Nov 05, 2012
    Remove the back panel wall of the freezer. You will see a drain hole in the center. You will need to clear this line out so the water will run to the pan under the refrigerator.
  • Simmone Nov 09, 2012
    hi richard . Do i do that from the inside of the refrigerator freezer right?
  • Richard Roth
    Richard Roth Nov 09, 2012
    From the freezer section.
    cool. i see a panel in back of the inside of the freezer. will do it in a bit . will let u know super
  • Richard Roth
    OK, I will be around!
  • Simmone Dec 28, 2012
    It's been a really long time . Sorry. I have the back of the freezer off. Hoe do I clean th e drain ..
    Sorry took some time off. Took the back off of the freezer off used the blow dryer. Now pouring how water thru the drain . Coils had a lot of ice. Now for the plastic drain how do clean?
    The problem is I have located the actual drain (tubing). And trying to fish out any debris but cannot get any type of pipe cleaner in the tubing.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Do you see any ice buildup on or behind the back freezer wall?
Posted on Nov 01, 2012
  • 1 more comment
    Hi Richard no ice build up at all.thanks
    cherokee2020 Dec 28, 2012 Sorry took some time off. Took the back off of the freezer off used the blow dryer. Now pouring how water thru the drain . Coils had a lot of ice. Now for the plastic drain how do clean?
  • 572 Answers
SOURCE: water is pooling on the top shelf and under the
ur drain is clogged. remove freezer panel and unclog hole where water collects
Posted on Feb 12, 2010
arikrom
  • 528 Answers
SOURCE: whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Posted on Jan 01, 2010
  • 98 Answers
SOURCE: water pooling under crisper trays
The drain is stopped up. take the top apart. The drain is in the middle at the back. get a hair dyer to throw the ice and you will see the drain. Do not break the from duct throw the ice. the drain is behind it. Air the the best way to unstop it.
Ken
Posted on Sep 26, 2009
iwillfixforu
  • 619 Answers
SOURCE: puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
Posted on May 28, 2010
  • 3 Answers
SOURCE: There is water pooling and
JUST FIXED THE SAME PROBLEM. In the refrigerator compartment at the top of the back wall there should be a drain hole. You may have to remove the plastic temp. unit & light. it should be one piece. You could probably let it hang by the electrical wires instead of disconecting, I did and had light to work by. I tried a wire coat hanger to unblock the drain but it wasn't flexable enough. I had some No. 12 Electrical wire, I stripped the plastic coating & used one piece of wire, it was plyable enough to get by any bends in the drain & strong enough to break up any blockage. My frige is just like new.
Posted on Mar 08, 2011
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Ice and water on the bottom shelf of my sears Kenmore regular refrigerator. things are cold but water pooling on the bottom shelf.it is a Kenmore freezer on top and refrigerator on the bottom
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Jan 18, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Puddles on top shelf and under crisper drawers
May 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
Water is pooling on the top shelf and under the crisper drawers
Feb 12, 2010 | Kenmore Refrigerators
Water pooling under crisper trays
Ken
Sep 26, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
444 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
